      09-07-2024, 07:17 AM   #1
josemigueltagorito
Drives: BMW G87 M2
Random noise/rattle in front dashboard
Hi,
I hace recently purchased a BMW M2 G87, one week ago. Less than 1000 kms already. I have a random noise coming from the front dashboard. It is around 4000-5000 rpm. On Thursday and yesterday was clearly noticeable, I went to my dealer and they noticed it. I will leave the car on Monday but for example today is not doing it.
It is random, first days only for a moment I had it, other days clearly noticeable and other days is not happening.
I hope the dealer can fix it.
I do not know if anyone had the same issue. Any help or info will be appreciated to give it to my dealer.
I really like the car, last one was a M2C and this new one IMO represents a very good evolution.
Thanks!
This a video with the issue:
https://youtube.com/shorts/D_Jd4TKGT...AXgGjMrC_5wQoG
      09-07-2024, 09:51 AM   #2
tylerdurdem
Drives: 2023 BGM M2
I had a rattle coming from the HUD, dealer was able to locate it and fix it.
      09-07-2024, 10:13 AM   #3
josemigueltagorito
Drives: BMW G87 M2
OK, good news then for you. The problem of mine that is also in front dashboard but in the passenger’s side or maybe in central position. Was your issue random? Mine is, I would prefer to be permanent to be easier to detect it and to fix it.
In the link with the video that I have posted, it is evident the rattle. I do not know if it is related with the central speaker, or a pipe behind the dashboard, or something different. It is complicated to determine the origin if it is random. Today I am not able to hear it.
Thanks for your response!
      09-08-2024, 11:32 AM   #4
tylerdurdem
Drives: 2023 BGM M2
Mine started out random, but eventually became constant if you weren't on absolutely virgin pavement, so it was pretty easy to identify. Who knows, maybe yours will get worse so it'll be easy to find too.
      09-08-2024, 02:35 PM   #5
nype
nype's Avatar
Drives: BMW M240i / BMW X5 35d
Sounds like what I am experiencing. Faint rattle coming from HUD area when driving on rough+ pavement.
Do you know of BMW has a tech bulletin out for this issue? Or what they did to fix it?
      09-09-2024, 07:10 AM   #6
josemigueltagorito
Drives: BMW G87 M2
Today leaved the car in the dealer. I had luck and today I was able to reproduce the vibration.
Now, I hope the dealer can find the origin. I will post updates to help other people.
Thanks.
      09-09-2024, 07:46 AM   #7
ajchoi
Drives: 2024 ZB M2 6MT
I had a rattle and figured out mine was something metallic I left in my glovebox vibrating against the glovebox sides at certain RPMs. Then I found another rattle and turned out it was my sunglasses in their case lol.
      09-09-2024, 09:02 AM   #8
tylerdurdem
Drives: 2023 BGM M2
Just some fabric tape. They found some in there already, like it had been rattling from the factory.
nype165.00
Carefree2261.50
      09-09-2024, 12:04 PM   #9
Cefoskey
Cefoskey's Avatar
564
Drives: 2024 BMW M2
1998 Porsche 944  [10.00]
2024 BMW G87 M2  [10.00]
I have the same rattle coming from either the A-pillar, HUD, or top of the door card. Sounds like this may be a known issue?
2024 G87.............| FGM | 6MT
1988 944.............| ZSM | 5MT
2006 355 Z71......| Red | 5MT
      09-09-2024, 12:43 PM   #10
josemigueltagorito
Drives: BMW G87 M2
Similar than mine, although in my case I identify it coming from the front dashboard, center or right side, but these rattles can be the origin confusing.
Still in the dealer, I am sure they have heard it so they should fix it. This rattle is not a normal behavior. They said to me that they will do their best to find the origin, I hope so. The problem of this rattle in my case is random, it does not depends on the roads. In a highway with excellent road conditions I was able to repro it. Hoping this can be definitely fixed and avoid to happening our worst nightmare: once the car is delivered to me, the rattle will be there again or dealer could create new rattles.
Thanks.
      09-12-2024, 03:00 AM   #11
Kettleboy
Drives: G29 Z4 M40i
Mines doing this too and I'm RHD, the only time its silent is on super smooth roads. dealers are a pita over here, i'd be interested to know how difficult it is to pop the bezel off the HUD? i
It does sound lower than that but these things can be deceptive.
      09-17-2024, 05:54 AM   #12
Kettleboy
Drives: G29 Z4 M40i
Ok, so I've had some success, it appears it was behind the cup holders, I've removed them and refitted with tape and foam, seems quiet at the moment..
      09-21-2024, 09:00 PM   #13
nype
nype's Avatar
The rattle I have stops when I grab the top left of the screen above the steering wheel and pull it towards me. Considering wedging something back there until it’s in for next servicing.
      10-06-2024, 05:18 PM   #14
n4owo
n4owo's Avatar
Drives: G82 M4 Comp xDrive
Thanks.
I have the same issue with my G82 M4 from the same spot and same sound. It has been in dealer for a week as they still can't figure out why it's making that noise. A field enginner is coming down to check on it. I have a loaner 330i from them but damn I miss my car
      10-07-2024, 02:39 PM   #15
josemigueltagorito
Drives: BMW G87 M2
Please, let us know if your dealer can find the fix and how. Mine is in the dealer also, I will update.
Thanks.
      10-07-2024, 08:16 PM   #16
n4owo
n4owo's Avatar
Thanks.
Due to incoming hurricane I have to pick up my car from the dealer today. It was rattling the whole way home I am losing it
      10-08-2024, 12:25 PM   #17
josemigueltagorito
Drives: BMW G87 M2
Wow, mine is still in the dealer.
      10-22-2024, 08:48 AM   #18
josemigueltagorito
Drives: BMW G87 M2
Third time in the dealer, they tried to fix two pipes isolation but is not the solution. The rattle is still there, with same intensity. It is a metallic vibration. The problem is a random rattle, some days is present, some days not. Begin thinking to return the car, incredible but true, I cannot assume to have this rattle in this car, when it is reproduced it is really annoying. Please, appreciate some help, thanks.
      10-22-2024, 08:55 AM   #19
Fastfwd
Drives: '24 G87 M2
I have a rattle. I have believed it was my dash-cam mounted too close to the rear-view mirror assembly, but now I'm not so sure. I'll need to remove that camera and see if it doesn't still do it. I almost hate to take it in and risk it being disassembled, but it's pretty obnoxious.
I had one coming from the rear deck area recently and it went away before I even tried putting the rear seats down and putting them back up to make sure they weren't a bit loose.
      10-23-2024, 01:53 AM   #20
josemigueltagorito
Drives: BMW G87 M2
I will wait to next week, if the dealer cannot fix it in this third time, I will return this car. I do not want it. Near 2 months that I cannot enjoy it. In my opinion quality and post-service are not enough.
