09-11-2024, 08:57 PM | #1 |
![]() 12
Rep 85
108b0a engine code
Hi how are you, I am looking for help I got this code 108b0a and it’s an intake sensor, don’t know if when they installed the Dme back they screw a conector can someone help me out? Or where is located maybe it got loose?
11-14-2024, 05:43 AM | #2 |
![]() ![]() ![]() ![]() ![]() 391
Rep 739
From BMWFault.Codes
Check if the following faults are entered, then rectify these first: - 1F1A93 - 1F1A95 Check lines and plug connections between the following components: - DME. - Charge-air temperature sensor. Replace charge-air temperature sensor. Probably a loose connection with the DME or whoever installed your DME was an idiot and didn't disconnect the battery and potentially short circuited something. Did you figure it out?
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
