BMW 2 Series Technical Topics (G42) Wheels / Tires
      09-13-2024, 12:37 PM   #1
bucketfoot
bucketfoot's Avatar
1248
Drives: 2024 BMW 230i xDrive
245 Square Setup
My car came with a 225 square setup, but I'm considering going wider.
Have people run a 245 square setup and if so how have you liked it?
This post sent using 100% recycled electrons.
      09-15-2024, 10:29 PM   #2
Dinosoar
Enthusiast
Dinosoar's Avatar
Drives: 2022 230i M Sport
2022 BMW 230i  [0.00]
I have a 255/35 square set up...love it! Highly recommend it. The turn-in and braking improvements are vast over the 225s.
8.5" rims with 30 ET. However, I have RWD, your xDrive may have different clearance concerns.(?)
      09-16-2024, 12:48 PM   #3
ryo-
Drives: '22 MWM M240i
I'm running 19x9.5 ET25 w/ 265/35 square setup on xDrive. just needed a 5mm spacer up front (and get longer bolts) and no other clearance issues on stock suspension. I'm assuming the 240 has the same suspension setup as the 230
      09-16-2024, 09:48 PM   #4
Red_sir
Drives: 2022 M240i
What tires are you running? Was it rubbing without the spacer, or you just got it as a precaution?
      09-16-2024, 09:56 PM   #5
ryo-
yeah, the tire/inner rim was against the strut body without the spacer. I am running PS4S
Red_sir182.50
      09-18-2024, 01:40 PM   #6
silver28
Drives: 2014 F32 435i xdrive 6 speed
Does the wheel stick out? Curious to see what 25 offset plus a spacer looks like? Any pics you can share?
      09-19-2024, 01:36 AM   #7
ryo-
it fits pretty well with the ZTK flares, though maybe a bit more negative camber would make it a perfect fit.
      12-28-2024, 07:06 PM   #8
ifound2pac
Drives: 2024 G42
So mine didn't come with the performance package but I am on RWD. Thinking of going with Conti EC Sport 2s, the options I think are between 235/40/19 or 245/35/19 on my stock 8" squared setup.
I think the latter makes more sense?
      12-29-2024, 08:25 AM   #9
kudos
kudos's Avatar
244
Drives: BMW M240i
Curious if the 245 option is still possible with lowering springs?
E90
