09-16-2024, 03:37 AM | #1 |
Rep 9
WINTER IS COMING (wheels/tyres)
Hey guys,
was wondering what option for winter wheels and tyres you will go with? (that will actually hit the snow and ice) Did anyone put any weight in the trunk? Or does the DSC do its job well even without? My M2 is my daily and i spend a lot of time on the highway where i might hit both ice and snow. Thanks pookies |
09-16-2024, 04:48 AM | #2 | |
Rep 1,228
09-16-2024, 06:16 AM | #3 |
Rep 1,429
My winter plan for Arizona is long sleeve shirts and occasionally jeans and not shorts.
Wheels and tires remain unchanged. |
09-16-2024, 06:23 AM | #4 | |
Rep 1,429
Or if Tire Rack is available to you, or something like it, see what winter wheel/tire sets are available for the M2. Best is to have a 2nd set of wheels for the winter tires. It is not advisable to remove/replace tires on a seasonable basis. Once mounted the summer tires need to stay mounted and likewise the winter tires. Which specific tires is open for discussion. I have no recommendations other than I would urge you to get real snow tires rather than all season tires. If you live/drive in an area that can require chains consider snow tires that can have chains or cables installed just in case you are required to fit chains to continue. For other RWD drive cars I put several bags of sand -- 50lbs IIRC -- in the trunk. I put the bags in a large plastic bin/tub in case I had to open a bag to use some sand under the rear tires. I also bought a shackle (two actually) that would fit in the tow eye and let me connect a long towing strap to the car in case I needed my car pulled from a snow bank. The other shackle was to help connect the tow strap to the towing vehicle. (Of course the sand comes out of the trunk at the end of winter.) If you have to have your car pulled from a snow bank be sure the pull is straight. Pulling to the side using a tow eye is to be avoided. (There might be something in the owners manual on this.) |
09-16-2024, 06:33 AM | #5 |
Rep 102
I went with Michelin Pilot Alpin 5 in stock dimensions (19"/20"). They did their job perfectly last winter, even in record-breaking snowfall where everyone was advised not to leave their homes. The snow was so deep I was scraping everywhere and didn't even get close to getting stuck. Both MDM and full DSC worked just fine without any trickery or bags of sand
09-16-2024, 07:16 AM | #6 |
Rep 1,228
09-16-2024, 07:16 AM | #7 | |
Rep 504
Drives: BMW G87 M2, F25 X3
I have never heard this before, what is the reasoning? That said my plan is to eventually get forged summer wheels and use the stock cast wheels for winter. I was able to find snow tires for them, but I could probably get away with some good all seasons given my car is more a weekendly then a daily. |
09-16-2024, 07:29 AM | #8 |
Rep 230
I had no issues last year in Michigan, the only issue that I had was my steep gravel driveway when it kind of melted and iced over but even then it was workable, I was more concerned about the random snow piles from plows that were running across the roads. But I went with Michelin Pilot Alpin 5 from BMW and they store my off season tire for $20 a season (roughly 6 months) so even storage isn't an issue. Never had to put sand or weight in the trunk but my daily commute didn't only consisted of 55mph speeds but slightly hilly areas.
I do need to get some spare rims however |
09-16-2024, 07:33 AM | #9 |
Rep 188
You’d have to re-balance them every time and deal with removing the adhesive, tire beads were not made for frequent manipulation, you risk scratching your wheels every time you have tires mounted, it’s just a hassle, the list goes on.
Only benefit seems to be not having to buy a second set of wheels. Can’t argue storage space either because tires take up the same space whether or not they’re mounted on wheels. |
09-16-2024, 07:55 AM | #10 | |
Rep 1,228
ednir98471.50 |
09-16-2024, 08:42 AM | #11 |
Rep 170
KristofX Check the G80/G82 forums in the classifieds section; there are frequently people selling their used winter wheels in that forum. It's good for understanding what sizes will fit and also to see what may be a really good option near you.
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
09-16-2024, 08:52 AM | #12 | |
Rep 102
They are available in Germany, actually with a star -OE BMW (there is also a normal version) https://www.reifen.com/en-de/28530-r...-3528700840926 Last edited by baj_baj; 09-16-2024 at 08:58 AM.. |
Ronin761314.50 |
09-16-2024, 08:55 AM | #13 |
Rep 1,228
09-16-2024, 09:26 AM | #15 |
Rep 691
sottozeros on the OEM rims from united tire. they were NOS dated 2021 but otherwise flawless. think i paid like $100 per tire. worked great for me, highly doubt ill get a third season out of them though.
09-16-2024, 10:11 AM | #16 |
Rep 175
Check these out that I'm selling. Used them once and the 245 width really kept me inline.
https://g87.bimmerpost.com/forums/sh....php?t=2130662 |
09-17-2024, 07:52 AM | #17 |
Rep 42
Ordered the winter whee'/tire setup from the dealer.
Style 641m wheels with Pirelli Winter Sottozero 3s. 36 11 5 A4D 827 36 11 5 A4D 829 $2,435 Came in two days later. |
09-17-2024, 07:56 AM | #18 |
Rep 282
Are you sure they are 641m wheels? Those don't have the same bolt pattern as the G8X cars as far as I know.
09-17-2024, 08:29 AM | #19 | |
Rep 42
Said they were plug and play for the G87, just need to swap the center caps. The part # shows as: Rdci Wheel Tire Winter B 000092 - BMW (36-11-5-A4D-827) Wonder if maybe it's similar to the 641 m and he was just sending me that photo as a reference? I'll update Thursday. |
09-17-2024, 09:11 AM | #20 |
Rep 10,250
I really want the PA5s. The US Michelin site says they make them in the stock M2 size, but I can’t find anyone that can get them.
https://www.michelinman.com/auto/tir...-pilot-alpin-5 |
Ronin761314.50 |
09-17-2024, 09:20 AM | #21 |
Car Geek
4129
Rep 3,828
These are part numbers for F87 winter wheels. The 5x120 bolt pattern is not compatible with the G87 5x112 bolt pattern. ET is also less than ideal and centrebore is larger, if adapters could be found for the different bolt pattern.
Albator_IIII1053.50 chris7197535.00 |
