BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      09-16-2024, 07:35 AM   #1
g87_la
Drives: M2 G87
Vibration at Idle
Anyone have a vibration at idle? I can feel it in my steering wheel and seats. To the point where my hands go numb while driving. Just started noticing it within the last few hundred miles. I haven’t made any modifications since it started happening. I do have resonated DPs and a single mid pipe with a valve controller. The vibrations do settle a little bit with the valves closed but it’s still very noticeable. I wouldn’t be concerned if my hands didn’t go numb.
      09-16-2024, 08:08 AM   #2
BroDoze
Drives: 2025 M2 LCI
Auto? You mean stopped at a traffic light, in drive with the brakes depressed?
///M
      09-16-2024, 09:17 AM   #3
g87_la
Drives: M2 G87
Correct. Stopped. In park. And yes I have an automatic. I see some g80 owners have experienced the same thing. But I don’t believe they came up with a cause or solution.
BroDoze2144.50
      10-12-2024, 11:22 AM   #4
Angmar
Angmar's Avatar
114
Drives: G87 M2 2024
Sounds like it’s exhaust vibration from your setup…Maybe the resonant frequency is causing it most likely. Unless it’s just straight up loose and vibrating which would feel worse at low rpm.
