      09-18-2024, 05:42 PM   #1
kudos
kudos's Avatar
299
Drives: BMW M240i
Tire pressure recommendations different between iDrive8 and door
The iDrive 8 tire pressure rec says the front should be 44psi and rear 42psi.
The door says front 38psi and rear 42psi.
Which one am I supposed to believe? It's a square setup.
E90
      09-18-2024, 06:54 PM   #2
eli371
Drives: 2022 m240i
pretty sure the idrive recommendations will change and are based on other variables like air temp
'04 RX8 - sold
'03 350Z - sold
'10 Z4 35i - RIP
'22 m240i
      09-18-2024, 11:39 PM   #3
Stick435
Drives: Pontiac G6 GTP
It might take into account type of tire too. Runflat vs performance/summer.
      09-19-2024, 08:00 AM   #4
LivingInSalt
Drives: 2023 BMW M240i
it doesn't matter. Run different numbers for a week at a time and see what you like
      09-19-2024, 09:33 AM   #5
inevitab1e
inevitab1e's Avatar
108
Drives: 2023 M240i G42
Are you tire settings manually set in idrive?
If so, make sure you have "<100mph" set.
      09-19-2024, 05:31 PM   #6
Littlecoupe
Drives: 2023 M240i
+1 for the <100mph setting in the tire settings (where you access the tire pressure monitor).
I learned this last year when it was calling up ludicrously high values. That >100mph setting is if you're regularly cruising over 100mph, like on the Autobahn, or a normal USA interstate.
      09-19-2024, 05:39 PM   #7
kudos
kudos's Avatar
299
Drives: BMW M240i
Or a regular street in Maryland.
E90
eli37157.00
