09-22-2024, 07:58 AM | #1 |
Rep 1,533
Technique for Adjusting MPHAS?
Has anyone adjusted their MPHAS height themselves? What teqnique do you use? Any step by steps to ensure level adjustments that don’t require re-alignment?
09-22-2024, 10:16 AM | #3 | |
Rep 3,655
From your post, I take it you haven't done this before? Take it to a reputable shop...and yes, car should be realigned with any height adjustment. |
Carefree2263.00 |
09-22-2024, 10:22 AM | #5 |
Rep 1,533
Not talking about install. Asking about adjusting slightly from port installed drop of -10mm down to -15 or -20mm.
According to this video looks like it should take 1min to do…. I guess you just jack it up and do equal turns on each side. Curious if anyone has done it before with MPHAS |
09-22-2024, 10:50 AM | #6 |
Rep 1,494
I intend to have mine lowered another 10mm from the port 10mm setting in late October.
I would never do this alone. No guarantee you’ll be able to measure precisely yourself. Then an alignment. Last edited by Carefree; 09-22-2024 at 10:53 AM.. |
Ronin761441.50 |
09-22-2024, 01:11 PM | #8 |
Rep 1,533
Hmm adding 5mm of drop (.2 inches) of additional camber from an already aligned car is probably ok right? Do these even camber plates? Sorry, I’m a newbie when it comes to this stuff, but I feel like there is a decent amount of camber to play with that won’t really harm anything driving or wear wise? I just used AI and it’s saying 5mm drop is essentially 1 degree of camber..
09-22-2024, 01:32 PM | #9 |
Car Geek
4258
Rep 3,905
"AI" being as inaccurate as is often the case and generalising things as it frequently does. It depends on the suspension design, with a BMW strut suspension, it will be a lot less than that, closer to 0.1 of a degree than 1.0.
09-22-2024, 09:40 PM | #10 |
Rep 1,354
09-23-2024, 05:19 AM | #12 | |
Rep 1,494
So you spend $70K on the car and then bitch about $150-$175, which is about 1/4 of 1% of the purchase price to have the car aligned correctly? Maybe you should ask for credit on the factory wheels and go for a set of deep dish hubcaps to save more $$$. Last edited by Carefree; 09-23-2024 at 05:28 AM.. |
Ronin761441.50 |
09-25-2024, 06:26 AM | #14 | |
Rep 1,494
The dealer performed the alignment as the port did not provide any proof. Last edited by Carefree; 09-25-2024 at 06:27 AM.. |
curtdragon664.50 |
09-25-2024, 06:52 AM | #15 |
Rep 1,533
Did you get one of these. There are only 3 checkboxes.
curtdragon664.50 |
09-25-2024, 08:16 AM | #16 |
Rep 2,295
My dealer has said every single MPHAS car they’ve received has needed an alignment bad.
If it has the option installed, they just automatically do it as part of the PDI now.
///M
09-25-2024, 08:29 AM | #17 |
Rep 1,494
Quite frankly that document is useless and unacceptable IMO. It doesn’t display any settings after lowering.
I received no alignment paperwork with delivery. Just my $.02 but I think port employees aren’t super interested in anything beyond installation of the HAS kit. My dealer performed the work along with a hard copy of the alignment settings. Last edited by Carefree; 09-25-2024 at 09:00 AM.. |
Ronin761441.50 |
09-25-2024, 09:40 PM | #18 | |
Car'a'carn
665
Rep 1,012
Problem is I'm doing PCD. So about 350 miles before it's home and rhe dealer is quite a bit away |
09-26-2024, 05:03 AM | #19 | |
Rep 1,494
There was no proof of proper alignment from the port, not even a ridiculous checklist. Last edited by Carefree; 09-26-2024 at 06:24 AM.. |
11-06-2024, 12:59 AM | #20 | |
You got my money?
4043
Rep 5,046
Drives: Ice Cream Truck
What a rude comment. 🤡
2025 G82 M2 6MT /// 2025 X5 40i X
11-06-2024, 09:39 AM | #22 |
Rep 286
Did anyone actually answer the OP original question? How to make adjustments to the suspension height.
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
