09-24-2024, 04:49 PM | #1 |
Rep 2,688
HUD drift / movement
Not quite sure if this is real or my imagination but I think my HUD may be on the move.
I have the vertical adjustment currently at +6. I’m sure I’ve adjusted it over the past 6 months from +4. Any lower and the bottom gets cut off the display area. If it was at 0, the whole HUD is below the display area. Car due for service in December so I’ll get it checked then but posting in case others have similar experience. |
10-25-2024, 12:48 PM | #3 |
Rep 2,206
I think I have a similar issue. I was recently adjusting the height and found that the bottom of it was getting cut off when it was at I believe 0. Granted, Im not the tellest person in the world so i attributed it to that and bumped it up a few notches.
10-27-2024, 11:13 PM | #4 |
Rep 1,791
I’ve noticed weird behavior like this a couple times. I have it set to +3 or 4.
I eventually notice it’s being cutoff at the bottom. I go into the display settings and it’s back at 0 offset. I raise it back up. At some point in the future, it ends up back at 0. Is this what you’re seeing? Or are you seeing that you have to keep raising it higher and higher. I attributed this to me using my other FOB briefly, like to unlike the car and it getting changed to the profile of the other FOB. Then when you open/start the car with the usual FOB, it doesn’t change it back to the other saved setting. Last edited by Fronzdan; 10-27-2024 at 11:13 PM.. |
10-28-2024, 03:48 AM | #5 | |
Rep 2,688
It’s been stable for the last few months. |
10-28-2024, 06:19 AM | #6 | |
equo non credere equitem
134
Rep 88
I've hypotheized that my posture may be the factor creating the impression that the HUD is, IDK, sinking on its own. So, I adjusted my seating position instead--but to no avail. Repositioning was a bit too awkward, anyway. Still, the HUD still seems to sink. I'm prone to user error--usually my first guess with things like this. |
10-28-2024, 07:57 AM | #7 | |
Rep 2,688
I now think the whole hud is a too high and has moved. |
10-28-2024, 09:48 AM | #8 | |
134
Rep 88
It does seem too high...agree, more noticeable/disruptive at night. |
10-29-2024, 03:17 PM | #9 |
Rep 218
Seat position, height and posture all impact the angle created between your eyes, the windshield and the projection screen on the dash. It's highly unlikely the the projector itself is moving and almost certainly isn't moving between different positions at different times of the day. It's you and the position of your eyes that is changing.
Obviously BMW can't program the 0 position to be perfect for all different drivers, that's why it's adjustable just like every other HUD I've experienced. Adjust it so that it just starts getting cut off at the top and note the setting. Then do the same for when it just starts getting cut off at the bottom. Set it right in the middle of those two settings. Then it should likely remain fully visible even with normal variations of eye position. If it's getting cut off then something about your position is likely changing more than you think it is. |
10-29-2024, 03:39 PM | #10 | |
Rep 2,688
I’ve had several BMWs with HUDs. None have moved and none had to be sitting this high on the screen to be seen. On the zero, it is cut off well below the coated area on the screen. Last edited by Pentland; 10-29-2024 at 04:16 PM.. |
mks133.50 |
10-30-2024, 06:12 AM | #11 | |
Rep 218
It’s a reflection on the windshield, so where your eyes are determines if it’s below the coated area as you describe. Different models also have different windshield angles and dash to seat proportions so different settings from previous cars may not be any indication of a problem. There is no way BMW can make it always reflect on the same area regardless of where your eyes are. One driver can be 5 foot tall with their eyes low and close to the windshield, while someone 6’5” has their eyes high and far back. Very different angles to the HUD as reflected onto the windshield. That’s why there is an adjustment and it seems the adjustment works for you. If you had the setting maxed out and it was still being cut off, then it would seem to indicate a problem. Let’s see what your dealer has to say. |
10-30-2024, 09:17 AM | #12 | |
Rep 2,688
Only I drive my car and the seat never moves. Same as all the other BMs I’ve had. I can accept my posture changes over the day but that doesn’t explain why a setting of say +4 is fine for several months then the hud has to be moved up again and say +6 becomes the norm. At the zero setting, regardless of your eye line the HUD is now below the reflective area on the screen. Something is drifting over (a long) time. It’s been fine for a while - since I started this thread. |
11-03-2024, 12:18 PM | #13 |
134
Rep 88
Just a follow up... taking mine into the dealership. My HUD is at the highest height setting but I have to stand up in the seat to see it. Was floating but still visible on a recent 600mi road trip. This morning, the setting was at the max height (I didn't set it there) but the display is sunk way below eye-sight level. My normal height setting is 2 or 3.
12-30-2024, 12:50 PM | #14 |
Rep 2,688
Follow up….
As expected, BMW say everything is OK. I’m not short by any means and I don’t have my seat slammed to the floor but slight movement down of my eye line and the hud will be cut off at the bottom. I think ultimately, it is what it is. In this car, the treated area of the windscreen is too high for the hud / seat comb and the HUD needs to be adjusted high for it to display. |
mks133.50 |
12-30-2024, 12:59 PM | #15 | |
134
Rep 88
Agree, that treated area does seem a tad too high. However, I can report that I haven't had any fluctuation/floating in a while...may (stress "may") have something to do with a recent install in which I disconnected the battery. I had to reset some of my preferences--too include the HUD level, the setting for which didn't remain fixed. No biggie, I set it back to the height and angle that aligns with my height/posture and seat position and haven't had the issue since. |
