09-28-2024, 04:13 PM | #1 |
Rep 937
Accessing The Rear Passenger Speakers
Is this going to require starting at the door sill trim, and pulling off everything up to and including the rear panels ?
Or is there easier access ? I replaced the door and dash speakers a while back , which was highly worth it. I figure I might as well do the rears. Any YouTube videos or tutorials on how to get to the rear speakers ? It's such a tight fit getting back there. |
09-29-2024, 03:40 AM | #2 |
Rep 11
Had to do exactly that procedure for a dashcam install and I can't see it being possible any other way. It's not terrible aside from having to pry off the panel while you're folded up in the back seat.
You will also probably have to pull out the seat bottom and the side bolster/airbag assembly in order to get enough clearance on the panel. Both are pretty quick. The seat literally pops off in two seconds |
VegasG42752.00 |
