BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      10-05-2024, 05:42 AM   #1
Shadak
Shadak's Avatar
84
Drives: M2 G87
Steering airbag removal
Sorry if this sounds stupid, but can I pop out the steering airbag safely without disconnecting the wires? I wont touch them, just nees to check the inside as there is some vibration going on and its too faint so dealer says its fine (obviously), its not horrible and not very noticrable over radio but my OCD knows its there. It stops when I push down on airbag so its something in there.
Or do I need to disconnect battery either way as long as I work in the area?
Thanks!
      10-05-2024, 07:51 AM   #2
BroDoze
Drives: 2025 M2 LCI
If you have to ask…
///M
      10-05-2024, 11:30 AM   #3
M_Power Rob
Drives: '23 M240 and '23 M2
Thanks!
So WHY are YOU wanting to remove the airbag?
      10-05-2024, 01:16 PM   #4
Shadak
Shadak's Avatar
84
Drives: M2 G87
because on some roads there is a vibration coming from the airbag area. Dealer says nothing is wrong so I want to check. I have fixed some things on my car myself and im fine with it, maybe its the inside wires toching something not sure. But when I hear the noise and hold the airbag with my hand firmly, it stops.
      10-05-2024, 01:52 PM   #5
M_Power Rob
So take a service tech for a ride on that road for them to hear/see it. You f*ck with the airbag, get into a wreck and it not deploy, you are screwed in more ways than one.
Hey, its your car and your life, do whatever you want.
      10-05-2024, 01:57 PM   #6
JABCAT
Professor
JABCAT's Avatar
4841
Removing the airbag is very simple. I wouldn't recommend taking a drive with it popped out, however. Here's what it looks like behind the airbag, not a whole lot to be vibrating back there.
*I recommend disconnecting the negative battery cable (10mm) and letting it sit for about 10 min before popping the airbag out. I use a #5 allen wrench to pop it out.
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo full Merino interior.
His: '23 M2, Toronto Red Metallic, M highlight interior.
'11 Callaway SC652 Carbon Edition Corvette Z06. Inferno Orange Metallic. 1 of 3.
BroDoze2333.50
      10-05-2024, 06:19 PM   #7
Shadak
Shadak's Avatar
84
Drives: M2 G87
Thank you, no i wouldnt risk driving it detached or tampered with.
Its just something buzzing on the top half of the airbag area, maybe one of those cables or the acrual airbag cable touching something. Thanks again for the pic, ill dc the battery if i decide to open.
