10-08-2024, 12:01 AM | #1 |
Rep 920
Dinan throttle booster install
Wanted to give everybody a quick review and "improved" install instructions for the Dinan (and likely other) throttle mappers out there.
First off - this thing is fun! All it does is remap your throttle response - but it sure feels like one hell of a performance mod. This came off my F87 and it works just fine & the G87 uses the same connectors. All good. To make installation a TON easier, you will want to remove the accelerator. To do this: 1. Remove the cap the red arrow is pointing to in the attached pic. 2. Use torx driver to remove the screw. 3. Push up on the entire accelerator and it will come free. It is held on by a metal tab that fits and clamps into the back of the pedal housing. 4. Now you can much more easily disconnect the plug behind the pedal & attach the booster. 5. Reinstall the accelerator. Screw it down, insert the cap. Get the app, do the pedal relearn process for the app. Pair the wireless module then so the pedal relearn process for the wireless module. Now you're done! Mount the wireless module wherever you want. I placed mine at the very top of the windshield. Push the wires up behind the plastic trim in the footwell. Mount the module wherever you want it & be sure it is out of the way. You need to be able to see the LED indicator when doing the pairing and pedal relearn so don't tuck it away where you can't see it - at least until you're done. Even the eco mode is an aok option. Actually is a little smoother at lower speeds than the stock setting. The max setting - total giggle inducing fun!!
2024 M2 | BSM | 6SPD | Port-Installed M Perf HAS | MAD Axle-back Exhaust | MAD CAI with blue filters | Dinan Midpipe | Richland Forged RF-GT3R Wheels Brushed Competition Gold & machined face | AudioControl D-6.1200 Amp & DSP | CDT Audio ES Gold Fronts & Rear | Morel BMW-Specific Subwoofers | Lots of neat interior upgrades!
10-08-2024, 09:51 AM | #3 | |
Rep 920
Where with the yellow ones, you're stuck with yellow unless you swap them back out. I am also thinking of getting the Monaco Motorsports CF & leather flat bottom steering wheel with heat! Not 100% sold on it yet.
BroDoze2155.50 |
10-10-2024, 12:01 AM | #5 | |
Rep 920
I was on the highest setting today and in M2 mode - it's ridiculous!
Resoelg325.50 |
10-11-2024, 01:05 PM | #8 |
Rep 920
I mounted the module in my trunk space, where the battery is. There are 2 grommets in there on each side you can pop out and fish the wires thru. I drilled a hole in the grommet & sliced it from center to edge so I could fit it around the wire. Then I popped the grommet back in & it's a super tight fit, no leaks!
most excess wire is also in the trunk but I left some underneath the car for slack & ziptied it out of the way.
10-11-2024, 09:15 PM | #10 | |
Rep 920
I stuck the module to the trim on the right side of the driver's footwell. I didn't want to hide it because I want to be able to see the LED on it while setting up, but also after set up in case anything goes wrong with the connection. The wireless controller is mounted at the top of my windshield.
10-11-2024, 09:29 PM | #11 |
Rep 55
I've got mine temporarily just above the pedal. I like seeing the LED as well--particularly as I just installed it, I'd like to see that it's functioning as intended. However, I'd like a cleaner, neater mounting solution...I feel like a clip or sleeve would do.
//Break//break// Yeh, old guy here...least that's what they tell me. |
10-11-2024, 09:55 PM | #12 | |
Rep 920
10-12-2024, 06:08 AM | #15 |
Rep 55
This may be the cleaner, neater solution for which I was looking. Realize a picture might not be that helpful--or possible. But how'd you physically manage to mount the module "above / on the under-dash cover?"
10-12-2024, 08:07 AM | #16 |
Rep 920
Yeah, I know. I'll get there. I went lazy man's route. Nothing moves or gets in the way for now. Plus now that I like it, I'll do a better install.
BroDoze2155.50 |
10-12-2024, 09:27 AM | #17 |
Rep 444
I used to think these throttle devices were BS until I got a Pedal Commander for my manual Bronco and it’s crazy how much more responsive it is. I couldn’t drive without it now. Definitely will look into this.
I do unplug and remove the one on my Bronco before going in for service. Maybe paranoid. |
10-12-2024, 09:37 AM | #18 | |
Rep 920
But, a throttle mapper shouldn't cause a dealership to flag your vehicle. It won't void your overall warranty, either. But like all mods, if the mod itself causes the problem that needs repair, then your warranty wouldn't apply. I don't see a throttle mapper causing any problems & Dinan's tunes are pretty reasonable. But #5 - that's gonna put a shit-eating grin across your face, if it doesn't make you downright laugh out loud! It's a howl for sure!
DrewNewM2880.50 |
10-12-2024, 10:35 AM | #19 |
Rep 1,604
This would mod be too redundant to a piggyback tune like the Racechip?
2024 M2
2019 M240i- Sold Last edited by JMcLellan; 10-12-2024 at 10:36 AM.. |
10-12-2024, 10:55 AM | #20 | |
Rep 920
@mikemike@x-ph.com r33_RGSport I will say this, given how intense setting #5 is with stock power, I would think a throttle mapper + a chip tune will really be outrageous. In a good way! I had this on my F87 that had a bootmode tune + Cart Jordan customization, and was full bolt on modded. That mapper gave the F87 that extra edge that made it all way more fun. I could see settings 1 (which is -20%), 2 & 3 being quit usable with # 4 being a usable scream. Setting #5, I'll use it as long as it isn't totally bonkers. It will be a lot of fun regardless!
r33_RGSport13692.00 |
10-12-2024, 10:58 AM | #21 | |
Rep 1,604
2024 M2
2019 M240i- Sold |
MASHCT1379.50 |
10-12-2024, 10:59 AM | #22 | |
Rep 19,123
You will need RaceChip XLR for throttle pedal input. A lot of guys doesn’t know about XLR. It is pretty much a gas/throttle pedal tuner.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com BLACK FRIDAY SALE is here !!! - Coupon Code "BF24" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • CSF • SPL and more... |
