      10-08-2024, 02:43 PM   #1
pg80
pg80's Avatar
114
Drives: BMW M3 C
Winter Wheel choices
I’m considering getting a winter set of wheels and I was thinking about style 359 but I can’t seem to find a picture of them on a G42 Does anyone know of anyone with those wheels on their car or another good option for winter wheels?
      10-08-2024, 03:23 PM   #2
IanH
Drives: '25 M240xi
OEM 359's will not fit the G42. But generally they look like any other mesh wheel if thats your style. You need 5x112 66.6 CB
I'm planning to relegate the OEM wheels to winter duty and buying summers instead. Nice because then spacers for OEM wheels wont be needed.
2025 M240i Xdrive TNM/Cog - On Order
pg80113.50
      10-08-2024, 06:49 PM   #3
advr6
Drives: E46 M3; G42 M240i; K49 S1000XR
I'm using the 898Ms as I have the ZTK package and the 19" wheels provide a bit more clearance to the rotors which is better for the slush we get up here in Canada
BPM2408.00
MJH215731.50
BmwIowa188.00
      10-09-2024, 08:10 AM   #4
ttaidapos
Drives: '23 X5 M50i, '24 M2
I have a wheel and tire set for sale posted, nearly brand new. 19x245 square coming from an M2.
      10-09-2024, 08:51 AM   #5
eli371
Drives: 2022 m240i
google "rim visualizer" and hit the canadawheels.ca link.
filter black wheels and find something similar and it will give you a good idea on how it looks
'04 RX8 - sold
'03 350Z - sold
'10 Z4 35i - RIP
'22 m240i
pg80113.50
      10-09-2024, 08:58 AM   #6
mks
mks's Avatar
69
Drives: 2024 M2
Fitment Issues?
I may be interested in this set. Any fitment issues (clear suspension, brakes), rubbing, etc. Using spacers? If these are what I'm looking for, I'll happily pay for shipping.
      10-09-2024, 01:16 PM   #7
pg80
pg80's Avatar
114
Drives: BMW M3 C
How can I find your post I also have ZTK on my car I forgot to mention it so your wheels will fit ?
      10-09-2024, 08:01 PM   #8
ttaidapos
Here's the post: https://g87.bimmerpost.com/forums/sh....php?t=2130662
I had zero fitment issues on the M2 with HAS and no spacers. I presume you will have no issues as well on the g42 with ztk.
      10-09-2024, 08:50 PM   #9
IanH
Drives: '25 M240xi
Why don't you just post the spec. M2 and g42 pretty different wheel fitments...
ttaidapos167.50
      10-10-2024, 07:49 AM   #10
ttaidapos
Specs (bolt pattern, dimensions) included in the sale post. I just don't have the offset. Trying to get it from the vendor. From what I understand, specs are the same besides break caliper clearance but I'm assuming if they clear g87 they should clear g42. Perhaps I'm wrong?
Wheels are flow forged, so better than stock but not better than forged regarding weight. Let me know what other specs you're interested in and I'll update the post. Thanks for the feedback!
      10-10-2024, 09:00 AM   #11
IanH
Drives: '25 M240xi
The offset is important, not just for clearing the brakes but also clearing the fenders. The fender clearance is different between the M2 and 240, by quite a bit.
I am not saying they wont fit M240 but nobody should buy them until the offsets are known.
ttaidapos167.50
      10-10-2024, 06:58 PM   #12
ttaidapos
Here are the specs on the wheels. Updated sale post as well.
Brand: GTS Wheels
Model: G510
Bolt Pattern: 5x112
Finish: Matte Graphite
Width: 9.5 inch
Center bore: 66.6mm
Offset: +25mm
Wheel Weight: 22.5lb
Load Rating: 1793lb
Lug Nut/Bolt Seat Type: Ball
Construction: Flow Forged
      10-10-2024, 07:41 PM   #13
IanH
Drives: '25 M240xi
The back the will definitely work but the fitment is 5mm inboard of stock wheels.
The front will be 27.7mm further in on the inside from stock. That's a lot more inboard, and should be test fit or confirmed from another user to not hit the suspension. Stock is 19x8.5 et 25,
No longer applies
ttaidapos167.50
      10-10-2024, 09:07 PM   #14
ttaidapos
Here are the specs on the OEM wheels of a G87 if it helps.
19x9.5 ET20 front
20x10.5 ET20 rear
      10-11-2024, 10:40 AM   #15
IanH
Drives: '25 M240xi
I found this post that shows 19x9 ET30
https://g87.bimmerpost.com/forums/sh...7&postcount=62
Quite close to the strut in the front.
Your wheels would sit 16.4mm closer, so for these wheels to work on 240 they will need a 12-15mm spacer.
9.5 is pretty wide for the front of the 240 though, it will be the absolute maximum poke with a 15mm spacer.
No longer applies spec is ET25
ttaidapos167.50
      10-11-2024, 12:27 PM   #16
ttaidapos
Ok, just received confirmation, i was way off. The GTS G510 wheel is made in 3 flavors with different offsets. +25, +40, and + 42.
The ones I have, are +25. I have updated the sales post as well to reflect the confirmation.
IanH222.50
