BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      10-17-2024, 08:34 AM   #1
msoyka87
Drives: 2022 M240i XDrive
2022 M240i Brake System Malfunction
Hello guys, 2022 M240i 42k Miles. I was driving this morning and about 7 minutes into the drive my car threw a “Brake System Malfunction” alert on dash as well as a “Chassis Stabalization Malfunction” with it. Car still runs and drives great and brakes properly. Havent driven the car in about 6 days if that makes a difference and its significantly colder than the last time i took it out. Any ideas on what i could be?
      10-17-2024, 08:47 AM   #2
IanH
Drives: '25 M240xi
Check the brakes for pad thickness, check the brake fluid level.
Clear the codes and see if it comes back.
2025 M240i Xdrive TNM - Dinan Springs - CF Goodies - More in process
      10-17-2024, 08:48 AM   #3
msoyka87
Ok I know I have definitely needed pads for a bit but is this the code it throws?
      10-17-2024, 09:42 AM   #4
IanH
Drives: '25 M240xi
Cant tell you exactly why the code went, but if you need pads you should do it....
