10-18-2024, 07:26 PM | #1 |
Rep 6,550
New MAD Product Release - MAD Yellow DRL LED Module Set - Fast Swap, Plug & Play
MAD Yellow DRL LED Module Set - Fast Swap, Plug & Play Upgrade your BMW with the distinct and dynamic MAD Yellow Daytime Running Lights, inspired by GT racing cars. These BMW headlights, featuring yellow daytime running lights, bring a racetrack-inspired aesthetic to your vehicle’s front end. Experience a captivating welcome sequence with yellow illumination when unlocking your BMW, and enjoy the striking look every time you switch on the low and high beam headlights. Now, you can effortlessly enhance your BMW with the same Mastery of Art and Design detail through our advanced LED boards for Daytime Running Light modules. The set includes pre-installed PCB boards with special thermal adhesive, designed for seamless installation and removal. This upgrade comes with low beam and high beam LED boards pre-mounted on an aluminum base, ensuring a perfect fit for both driver and passenger side headlights. Effortless installation with pre-installed PCBs on aluminum housing—simply unplug and swap out the old aluminum housing with no need to glue the PCBs to the OEM housing.
