BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      10-21-2024, 01:46 AM   #1
Paulm2
Paulm2's Avatar
12
Drives: bmw 335i 2013
Upgraded turbos m2
Hi I am thinking of upgrading my turbos but have some doubts. Somebody already did it?
      10-21-2024, 10:07 AM   #2
Mkai0
Drives: M2,Civic Si,4Runner, Lex GX460
What are your doubts? These cars are very capable of handling turbo upgrades.
In my opinion traction will be our biggest challenge when making over 600hp and
torque on these cars.
      10-21-2024, 11:25 AM   #3
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
lots of people upgraded their turbos, this is an excellent platform to do that as it can handle a lot more power than stock
https://x-ph.com/sale/
Phone number 702-494-9435
      10-21-2024, 11:38 AM   #4
Paulm2
Paulm2's Avatar
12
I have a custom flex fuel tune, with it work with it, also I have the eventuri do they fit in the new venturis? Do I need to upgrade my transmissio ? I am running xhp stage3.
What are the power gains in a reliable setup with e60.
      10-21-2024, 02:05 PM   #5
mike@x-ph.com
i recommend you check with your tuner on what kind of power they can offer you with the current setup and whether the upgrades would be beneficial.
      10-21-2024, 03:30 PM   #6
rons e92
60-130 Enthusiast
rons e92's Avatar
My car made 780whp on e78 with port injection and upgraded fuel system. Stock engine, trans, and turbos. If I was ever able to drive it it should have been at least mid 9s capable and it ran mid 5s 60-130.
You can't make too much more power on stock transmission. Even with my tune, my daily flex fuel map was 760whp and 640wtq. My kill map was 780whp 760wtq, but that map was only for gears 1-6. 7th or 8th would have bent a rod as per my tuner.
Considering trying to go DI only and do hybrids on my new G87 just to see what we can get out of that kind of setup.
PI can be a pain sometimes.
      10-21-2024, 04:27 PM   #7
97supratt
97supratt's Avatar
164
Drives: BMW, Toyota, porsche
How much more power can the manual handle?
      10-21-2024, 04:30 PM   #8
rons e92
60-130 Enthusiast
rons e92's Avatar
None, it can't take any where near as much power as the auto and has virtually no aftermarket support. If you were after big power in the near term you bought the wrong transmission.
      10-21-2024, 10:14 PM   #9
curtdragon
Car'a'carn
765
Drives: I drive one
Incorrect. There are a few clutches out there and there are builds that are 800+ as well and single turbo. The actual transmission is stronger. It's the stock clutch that's the weak point.
You say there's no support but how many companies are actually building autos? Two? There aren't a bunch of threads in this forum but there are some in the G80/82 forums.
Agreed about choosing the wrong platform for big power. The G87 isn't it auto or not. Not until there's xdrive. Or you set the car up specifically for rwd drag
DrewNewM21207.00
daddyjaxx116.50
      10-21-2024, 10:58 PM   #10
rons e92
60-130 Enthusiast
rons e92's Avatar
This is exactly what my last G87 was for, and what my next one will be for. My friends and I build these cars and race them.
Show me a manual G8x car that runs low 9s consistently and I'll accept your assertion.
A few anecdotal examples doesn't mean anything. My G87 on kill would send 760 ft/lbs of torque to two 315 radials through a stock transmission. Does this mean it's safe to do this and it's a good idea? Absolutely not.
My friend with a single turbo manual G87 would agree with me as well.
You could be right longitudinally, but as of right now the sample size is small. I consistently hear from people I know who have high hp manual G8x cars, auto is better and safer (and faster) if you plan to turn it up and go fast.
      10-21-2024, 11:09 PM   #11
curtdragon
Car'a'carn
765
Drives: I drive one
I think we all know the reason why there aren't a huge amount of high powered manuals. Most people who buy then want the engagement aspect of the manual and more power is second or not even on the list. I was back and forth and for me between auto and manual. Manual won but I'll be happy with a clutch upgrade and a DI only flex fuel tune. I want flex so I don't have to worry about mixing. If I wanted big power I'd go with the M240. Essentially built for built the outcome is near the same.
I haven't heard of many manual transmissions breaking period. But definitely heard of auto needing rebuilds
DrewNewM21207.00
daddyjaxx116.50
      10-22-2024, 11:02 AM   #12
DrewNewM2
Drives: Brooklyn Grey G87 Manual
Manual should be as capable of big power with a clutch upgrade. Quite a few G80 manuals out there with upgraded turbos, etc. personally I would rather have a 600 whp manual than an 800 whp auto. I don’t street race or drag race so not looking for numbers really. The only exception I could make is being convinced of forgoing manual for an Xdrive for all season driving and traction. Whether auto or manual, limited factor is traction with RWD unless you want to drive around on drag radials and then the car doesn’t handle great and can’t go in rain.
If BMW ever made an S58 manual Xdrive M car, it would be the ultimate
      10-22-2024, 02:06 PM   #13
97supratt
97supratt's Avatar
164
Next year I believe.
      10-22-2024, 02:13 PM   #14
BradMX5
BradMX5's Avatar
685
Drives: 2025 M2
Auto only
DrewNewM21207.00
daddyjaxx116.50
      10-22-2024, 02:14 PM   #15
DrewNewM2
I wish but not with manual.
