11-01-2024, 12:03 PM | #1 |
Professor
4841
Rep 3,178
MAD Resonated Mid-pipe Install Questiions
Trying to install the MAD resonated mid-pipe & am running into a couple issues. No installation instructions included (shocking) & the installation video MAD links to is awful. This should be pretty straight forward & I've installed many sets of headers & exhaust systems on many different vehicles. End rant.
1st question is the diameter of the opening on the MAD mid-pipe is smaller than that of the stock pipe where they meet the down pipes (pic attached). The stock pipes have a removable ring where the pipes meet. If I leave this ring on the down pipe, the MAD pipe won't seat properly. 2nd question is the two short pipes that connect the middle section to the axle-back exhaust are noticeably smaller in diameter than the pipes they connect to on the muffler. The band clamps provided don't seem to cinch down tight enough to keep the smaller pipes from moving inside the larger pipe. I have the MAD axle-back so I would expect a much more snug fitment. 3rd is the mid-pipe didn't come with the MAD brace so where do I use & how many washers have you used on the stock brace. Thanks!
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo full Merino interior.
His: '23 M2, Toronto Red Metallic, M highlight interior. '11 Callaway SC652 Carbon Edition Corvette Z06. Inferno Orange Metallic. 1 of 3. Last edited by JABCAT; 11-01-2024 at 12:36 PM.. |
11-01-2024, 01:06 PM | #2 |
Professor
4841
Rep 3,178
Nevermind - it's moot now. Trying to get the MAD pipe to seat correctly I over-tightened & snapped one of the bolts on the down pipe flange. There's enough threads left to connect the stock pipe, so that & the Dinan x-pipe are going back on for the time being.
11-01-2024, 02:27 PM | #3 | |
Rep 432
I need to double check mine and see if the downpipe connection is leaking or properly sealed. I wonder if anyone else had less than perfect downpipe to midpipe fitment issues with the MAD single midpipe?
-Nicholas
2024 BMW M2 2022 BMW m240i x-drive (sold) 2018 BMW X5 35d x-drive 2015 VW Golf 1.8t 5-speed (sold) |
11-01-2024, 02:30 PM | #4 |
Rep 319
Info@mad-us.com Tagging you because you might want to see these posts and take back to the technical/QA team.
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
11-01-2024, 02:37 PM | #5 |
Professor
4841
Rep 3,178
Another member had his resonated mid-pipe installed and it appears to fit flush based on the photo he sent me. Mine definitely did not come anywhere close to fitting like this below.
11-01-2024, 03:06 PM | #6 |
Rep 11
I have the same issue with the MAD non-resonated midpipe, can't get the bottom flange to seat with the gasket on. Tried to test fit with the crossover pipe flange and it does look like its slightly too small to fit. Regarding the cross brace - I didn't receive one either and they are supposed to be shipped out later.
11-01-2024, 03:47 PM | #7 |
Joint Chiefs of Staff
28045
Rep 197,965
you should contact MAD directly for faster help
11-01-2024, 04:07 PM | #8 |
Rep 6,888
Currently looking into this issue.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices! 5% OFF Code "BimmerPost" Email: info@mad-us.com |
11-01-2024, 04:09 PM | #9 | |
Rep 6,888
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices! 5% OFF Code "BimmerPost" Email: info@mad-us.com Last edited by Info@mad-us.com; 11-01-2024 at 04:21 PM.. |
11-01-2024, 04:24 PM | #10 |
Rep 432
I have the downpipe flange nuts tightened like it was tightened by Zeus himself and this is as good as I can get the midpipe to go on the downpipe flange.
-Nicholas
2024 BMW M2 2022 BMW m240i x-drive (sold) 2018 BMW X5 35d x-drive 2015 VW Golf 1.8t 5-speed (sold) Last edited by Good 4 2 reasons; 11-01-2024 at 04:31 PM.. Reason: uploading better photo |
11-01-2024, 04:34 PM | #11 |
Rep 11
Yes, the top downpipe fits fine, the bottom one doesn't go much further than this. I could feel the bolts straining and did not want to strip the threads pushing it more
11-01-2024, 04:41 PM | #12 | |
Rep 6,888
1.The two flanges do not have to be completely flush to get a great seal the connection in this photo looks just fine on the upper pipe. 2.Both flanges are identical in size and made via cnc machine so the tolerances are extreme small. Based on all the photos posted what appears to be happening is not related to the gasket but it it looks like the downpipe extension is possibly binding up on the inside of the pipe after the flange due to the angle. I would advise to unbolt the top connection first and seat the lower one then the top. Do not overtighten the nut if the gasket is not sitting flush.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices! 5% OFF Code "BimmerPost" Email: info@mad-us.com Last edited by Info@mad-us.com; 11-01-2024 at 04:48 PM.. |
11-01-2024, 04:53 PM | #13 | |
Professor
4841
Rep 3,178
11-01-2024, 04:54 PM | #14 |
Rep 432
The second downpipe also had a significant gap as well.
What is the torque target? It will be quite easy to tighten to your recommendation, on the bottom connection first, then attempt the top, and if they are leaking, I will know if I have an issue.
-Nicholas
11-01-2024, 05:01 PM | #15 |
Rep 6,888
Torque spec is not that high like 16 ft lbs . We use a concave style flange that is shallower compared to stock so as long as the gasket is flush it will not leak.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices! 5% OFF Code "BimmerPost" Email: info@mad-us.com Last edited by Info@mad-us.com; 11-01-2024 at 05:31 PM.. |
11-17-2024, 02:24 PM | #16 |
Rep 432
Update:
X-PH approved an RMA on the MAD midpipe. Originally, they (not sure if it was MAD or X-PH driving the bus) wanted me to modify the piping coming into the exhaust flange fitting for a $70 refund. These exhausts aren't cheap, my time is valuable, and trying to put the responsibility on the customer to fix something that should have been caught in QC is disappointing. Thankfully X-PH agreed it was best for me to send it back. I ordered the Active Autowerks non-resonated single midpipe from X-PH. Shipping was pretty quick and the effort in packaging was worlds better than the packaging job from MAD. Install of the AA midpipe was definitely a tighter fit in every aspect, but I took my time, and everything installed correctly with no leaks on first start. I was able to install everything with the recommended torque on every bolt. It was also nice to receive the exhaust with the brace. I know the MAD brace was delayed, and the brace not being available to ship at launch was listed on the page, but I think providing $0.50 in spacers so people could use the factory brace would have been the best way to deal with the delay in the brace. I will also say the recommended cuts on the factory piping, there was a very small gap mounting up the AA midpipes, with a much larger gap for the clamp to bridge on the MAD midpipe. According to my emails with MAD, this is a random occurrence with the three of us on the forum, with hundreds of midpipes sold with no issues. I can't speak to MAD's QC procedures, but just wanted to share my two cents. I will include photos of why my MAD midpipe would not seal at the downpipe sections due to the MAD midpipe not being properly tucked into the flange fitting.
-Nicholas
11-18-2024, 02:14 PM | #17 |
Rep 6,888
I apologize for the issue you encountered with our midpipe. This thread is the first time we've been made aware of this problem, and it appears to affect only a few midpipes and exclusively with OEM downpipes. Rest assured, we are now inspecting every single midpipe going forward to ensure proper fitment.
A recent customer install over the weekend with OEM downpipes fit flush without any issues, so this seems to be an isolated case.
- Click Here
JMcLellan2905.50 |
11-18-2024, 04:08 PM | #18 | |
Rep 432
-Nicholas
mks123.00 |
11-18-2024, 08:04 PM | #19 | |
Professor
4841
Rep 3,178
mks123.00 |
11-19-2024, 12:19 PM | #20 |
Rep 6,888
Please reach out to the dealer you purchased it from so we can move forward with a resolution.
- Click Here
11-19-2024, 03:17 PM | #21 |
Professor
4841
Rep 3,178
Info@mad-us.com3398.50 |
11-30-2024, 08:46 PM | #22 |
Rep 8
I have just received my midpipe and I did not see the MAD brace in there. I will not install it until I receive confirmation from MAD that the brace is not supposed to included in the box for the RESONATED midpipe.
