11-05-2024, 01:31 PM | #1 |
Rep 9
Lowering springs RWD vs XDrive
I am looking at lowering springs for my m240 RWD, but almost every set I've seen says it's for the XDrive version. Does anyone have a recommendation?
11-06-2024, 03:11 PM | #2 | |
Rep 343
https://autoid.co/products/bmw-2-ser...43349163376869
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
11-14-2024, 12:28 AM | #3 |
Rep 35
I have the Cobra suspension on my car, it's good, has moderate drop, and is not as stiff as the H&R. Comfort mode is great and comfortable around town. Honestly, you can't go wrong with any springs available right now just depends on what you want.
Eibach - Moderate Drop - OEM ride-like quality. Cobra - Moderate-High Drop - Slightly Stiffer than OEM - Keep in mind Cobra is not in NA anymore so if anything happens you will be dealing with them in Asia. H&R - High Drop - Stiffer than OEM. Some say the OEM Sport Plus becomes comfort with H&R springs installed. (not my take). There are also AST and other brands but like I said their difference is negligible. Dinan also released there's with a bumpstop kit which might be worth looking into. The difference in X-Drive springs is the springs rates I believe, I think someone on here said the part numbers for the M340i and 240i are the same for Eibach, but take it with a grain of salt. Here are some springs that are RWD-specific or have RWD as part of their compatibility list. https://ind-distribution.com/collect...ing-spring-set https://www.turnermotorsport.com/p-5...xoCzKEQAvD_BwE https://autoid.co/products/bmw-2-ser...43349163376869 https://motonsuspensionusa.com/produ...ront-25mm-rear Last edited by bozo777; 11-14-2024 at 12:42 AM.. |
