      11-07-2024, 11:17 AM   #1
fast330i
@fast330i
fast330i's Avatar
Romania
Drives: G20 - 330i - 2019
Rear diff leak, any ideas?
Hello, I’ve recently noticed I have a lot of leak on the rear differential, anyone ever encounter this?
I’ve did some search and came up to this:
https://bmwrepairguide.com/sib/330315.pdf
Anyone else thinks this is the cause?
Car: X5M 2017 F85
      11-08-2024, 12:29 PM   #2
John H.
John H.'s Avatar
Drives: 2022 G15
Clean the area with brake cleaner. Re-check area.
That being said, there appears to be much moisture. Check for loose bolts. Also, check the shaft seals.
      11-08-2024, 12:42 PM   #3
tdott
S.FL S65 Specialist
4088
dont be lazy, take the shields off.
Check the front and sides to see if it is leaking from any of the seals. Those are the most likely places for it to leak.
      11-10-2024, 10:21 AM   #4
RockCrusher
No experience with BMW diff leaking. But the front diff leaked on my 996 Turbo. Turned out to be the axle flange seals.
As has been suggested clean the diff thoroughly with brake cleaner. If you can remove the shields first.
After the diff is clean drive the car for a while then back home on your driveway back car onto ramps and with a bright light look over the diff.
