BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      11-08-2024, 11:44 AM   #1
Speedy3
Drives: 2025 M2
40mm Spacers for Winter setup
Has anyone run a 40mm spacer on the rear?
I have a square winter setup 19x9 et20 with 275/35/19's. I'm going to run the 15mm spacer I have for the fronts but the rear could use more. Any issue with running a 40mm spacer on the rear? Anyone have a source for high quality 40mm spacers for the g87?
Thanks in advance!
      11-09-2024, 11:33 AM   #2
BroDoze
Drives: 2025 M2 LCI
///M
      11-09-2024, 12:46 PM   #3
M_Power Rob
Drives: '23 M240 and '23 M2
Originally Posted by BroDoze View Post
Yeah, don't think I would go with the thick of a spacer under any condition.
aerobod4372.50
      11-09-2024, 05:54 PM   #4
Speedy3
Drives: 2025 M2
It’s funny. I come from a raptor/jeep/bronco offroad world and a 1.5 inch spacer is totally normal and used offroad under high stress situations. Billet aluminum and usually bolted to the hub, and then wheel bolted to spacer (not a sandwich style).
