      11-12-2024, 01:41 PM   #1
DDG61EW
Drives: Chevy SS
AC Fan Speed "Auto"
All,
Good morning, regret having to ask this question but have read the manual and search but can't believe the "answer".
Do our M2s not control the fan speed when the AC is in Auto? Doesn't matter what temp i select or the current temp the fan stays on whatever speed i have manually selected.
Thanks.
      11-12-2024, 02:00 PM   #2
aerobod
Car Geek
aerobod's Avatar
Originally Posted by DDG61EW View Post
All,
Thanks.
In Auto, it seems to use the selected "preferred" fan speed if the air blend can reach the temperature selected. If the temperature is not achievable it will then start to vary the fan speed, returning to the "preferred" speed if it can when the temperature is reached. From my experience, this is the way it has been for other F & G-series BMWs I've driven.
      11-13-2024, 09:06 AM   #3
DDG61EW
Drives: Chevy SS
Is this what you are actual experiencing? I'm in Dallas and on a 88 degree day with the car parked in the sun placing the AC on "low" and "auto the fan doesn't adjust at all.
You have witnessed your fan adjusting speeds in "auto"?
      11-13-2024, 07:27 PM   #4
aerobod
Car Geek
aerobod's Avatar
Yes - Automatic Program enabled in iDrive, sync on, medium intensity. I then just set the desired temperature and the fan speed adjusts if necessary. I also have the rear climate control system (2023 car).
Ensure when Automatic Program is enabled that the up and down arrows are not used for fan speed, but instead tap the large or small air flow icons, otherwise it won't change the fan speed from manual mode that the up and down arrows enable.
      11-14-2024, 08:42 AM   #5
RockCrusher
Interesting bit of info.
But I don't see the large/small air flow icons you speak of. I've only used the +/- controls to change/set cabin fan speed. I would very much like to have the fan speed under automatic control. My other cars with auto climate control were superb in keeping the temperature in the cabin just right with no need to play with the controls at all. One reason was the fan speed was under auto control.
Later at the car I'll tap various areas of the display to see if I can figure out how to get fan speed under auto control.
Nevermind. I read the owners manual (!)...
Setting the intensity
General information
When the automatic program is activated, the intensity of individual climate control functions can be individually adjusted, for example:
▷ "LOW"
▷ "MEDIUM"
▷ "HIGH"
Each level has a specific control range of the intensity.
Based on the stored data models, the intensities are dynamically adjusted while driving. It is not necessary to manually change the desired intensity to lower or higher levels while driving.
But I have to mention the dynamically controlled fan intensity doesn't seem to be as good as I would like.
      11-14-2024, 11:02 AM   #6
JABCAT
Professor
JABCAT's Avatar
4904
I'll go so far as to say the "auto" program sucks. It's much worse than the previous climate control settings in iDrive 7. At least in the previous version you could set specific temps at which the heated seats & steering wheel would activate & it controlled the interior temp better. It was 43 degrees driving into work and no heated seats or steering wheel & the car was blowing a/c However, it's activated the heated seats when it was 73 degrees outside & I couldn't figure out why I was sweating until I looked over at the screen.
      11-14-2024, 01:23 PM   #7
aerobod
Car Geek
aerobod's Avatar
General information
▷ "LOW"
▷ "MEDIUM"
▷ "HIGH"
Actually I think the large and small icons I mentioned is incorrect in the current software implementation, they are not present, I've attached what it says in the manual, that seems to be incorrect. I've also attached a short low quality video in a zip file that shows the fan speed varying by just altering the temperature when the Automatic Program is selected and the fan speed is just set to Medium intensity, as opposed to the fan speed being manually adjusted. The video also shows the automatic activation of the seat heating as the temperature selected varies.
      11-15-2024, 09:37 AM   #8
RockCrusher
Believing what I read in the manual about the fan speed being dynamically controlled I was out and about yesterday and I tried the fan speed setting at several different settings starting with medium and the fan speed did not change at all.
I don't think the auto climate control in my M2 works the way the manual says.
From last winter I do seem to recall the seat heating works as you describe.
      11-15-2024, 12:56 PM   #9
ajchoi
Drives: 2024 ZB M2 6MT
My B9 Audi A4 and S4 had that neat little temperate display within the automatic temperature dial, and when the auto button was pressed, adjusting that dial adjusted everything else automatically, the fan wasn't even part of that setting it just blew faster or slower depending on ambient temperature...that seemed fine and better than this weird setup where BMW seemed to add machine learning just because they could haha
      11-15-2024, 01:00 PM   #10
tylerdurdem
Drives: 2023 BGM M2
I actually kinda like having control of the fan speed at all times, sometimes auto systems absolutely blast you when you'd rather it not.
      11-15-2024, 04:44 PM   #11
aerobod
Car Geek
aerobod's Avatar
It does work as expected on my car, you can hear the fan speed change as I increase the temperature (without touching any of the other settings) in the 5 second video I attached in the previous post. When I decrease the temperature, the fan speed drops down again.
The air blending to change the temperature seems to be a priority over fan speed (changing the volume of air supplied) unless HIGH or LOW is reached in the temp setting, though.
      11-15-2024, 04:51 PM   #12
beren
beren's Avatar
133
Drives: 1988 Porsche 911, 2024 BMW M2
My fans change speed for sure.
aerobod4383.00
      11-15-2024, 04:57 PM   #13
aerobod
Car Geek
aerobod's Avatar
I'm wondering for those that don't have the fan speed change, whether any coding customisation has been done on those cars?
Some people who permanently coded out the ASS setting experienced unexpected release of the parking brake. This wasn't just in G87s, either, other BMWs (and Supras) with iDrive 8 have also seen this issue. Unrelated coding changes do seem to have the capability to affect other functions that are not directly related.
      11-15-2024, 05:47 PM   #14
Good 4 2 reasons
Good 4 2 reasons's Avatar
705
Drives: '24 G87 M2 6MT
That was me. Definitely a good point. A trivial setting change in bimmercode affected a crucial safety system.
It definitely seems the fan speed changing from the preferred setting (while set to auto) is very dependent on the current cabin temperature, the desired cabin temperature, whether the cabin air is being filtered, etc. As much as BMW loves to complicate systems, I could see the amount of cooling/heat due to the coolant temperature impacting the fan speed as well.
-Nicholas
2024 BMW M2
2022 BMW m240i x-drive (sold)
2018 BMW X5 35d x-drive
2015 VW Golf 1.8t 5-speed (sold)
aerobod4383.00
      11-15-2024, 10:53 PM   #15
DDG61EW
Drives: Chevy SS
Stock, no coding.
      12-16-2024, 06:25 PM   #16
DDG61EW
Drives: Chevy SS
Circling back on this one. I was able to confirm my fan speed is adjusting as needed over the weekend. Figured out that the actual visible display (level the fan is blowing) never changes from your setting regardless the level.
This was my confusion. Thanks.
