      11-26-2024, 10:25 AM   #1
bmwloverx
Drives: E90 e53 e71 f15 f16
Do I have ibs problem or water pump problem
I have n55 engine. Is ibs causing lin problem and then messes up water pump or water pump causing ling problem and messes up
ibs? Please check attached picture.
I cleared errors. Removed ibs, drove 10 miles problem not came back. Connected ibs back, drove again 20 miles, no errors.
I tested car with ista because water pump was turning on itself after turning off engine.
P.s.
I did bleed from ista. Water pump speed was 30-200. Ista gave these numbers.
      12-02-2024, 10:57 AM   #2
bmwloverx
No experience?
      12-02-2024, 07:01 PM   #3
thebmw
Post Advisor
thebmw's Avatar
1909
Drives: More Manuals than Automatics
I thought you were talking about IBS and water problems in regards to the bowel and the bladder problems. I could have helped you there. Can't help you with your car issue though.
pz6193338.50
      12-02-2024, 08:39 PM   #4
vt100
vt100's Avatar
135
Drives: '06 Z4MC, '12 128i
How old is the water pump? Considering it's N55 and if it's older than 50kmiles I'd replace it just to be on the safe side.
