BMW M2 Forums 2023+ (G87) Regional Forums UK
      11-29-2024, 11:37 AM   #1
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
Zunsport needs your 2025 M2 for a test fit!
Hey yall!
If you are in the UK and have a 2025 M2, Zunsport needs you for a test fitting of their screens. What they usually do is set up you with a free set of screens to compensate you for your time.
If you are available, let me know and I will get you in touch with them.
Thanks!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
      11-29-2024, 06:03 PM   #2
DDG61EW
Drives: Chevy SS
Isn’t the area covered by the screens identical 24/25?
I must be missing something.
      11-30-2024, 06:36 PM   #3
Whytar
Whytar's Avatar
Australia
36
Drives: 2025 Portimao G87 M2 LCI
I hope they are identical. I've just received my order from Zunsport for my LCI coming at the end of Dec.
DDG61EW18.00
      12-01-2024, 01:58 PM   #4
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
They want to double check on a new 25, so I would take them up on it.
      12-01-2024, 07:20 PM   #5
nerdthewise
nerdthewise's Avatar
20
Also hoping they are identical after installing them on my ‘25 (no issues)
      12-06-2024, 06:16 PM   #6
DD99990
DD99990's Avatar
32
Drives: BMW G87
Originally Posted by BMW DIY Guy View Post
Hey yall!
Thanks!
You’re Cannock based aren’t you? I’ve just had delivered my new G87 and live in the area! I’m interested 🤙🏼😊
      12-06-2024, 09:46 PM   #7
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
Shoot me a DM with your email and contact info, and I will get you in touch with them.
      12-06-2024, 11:53 PM   #8
DD99990
DD99990's Avatar
32
Drives: BMW G87
Hi. As I’m still new I can’t dm yet but hmu on davedovey3@gmail.com thanks!
      12-06-2024, 11:58 PM   #9
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
Gotcha, I sent your info onto them!
DD9999031.50
      12-10-2024, 03:18 AM   #10
DD99990
DD99990's Avatar
32
Drives: BMW G87
No messing around…
      12-10-2024, 03:48 AM   #11
DD99990
DD99990's Avatar
32
Drives: BMW G87
They’ve confirmed they are identical
M27148.00
      12-12-2024, 01:47 PM   #12
M271
M271's Avatar
48
Drives: BMW G87 M2
Now I'm seeing all these photos of the full Zunsport grills I'm needing to add to the one I have, looks so much more complete to have all five across the front.
Not 100% sure the four smaller grills are totally needed, the coolers/rads behind each of the larger side intakes already have the factory fit plastic protectors on my '23 car. Are the two smaller intakes for the brakes or cooling?
The oil cooler grill is on order, should be here in a day or so.
      Today, 12:57 PM   #13
Blacktemplar
Blacktemplar's Avatar
3658
Drives: G87 Batmobile
It defo looks a lot better without that gaping great maw!
I fitted the central and outer two grilles, but left the other two off. Partly because the fit is a bit awkward and partly because the channel through to the radiator is angled and the likelihood of a stone/debris getting through is reduced.
Is your '23 a manual? Mine is '24 auto and doesn't have any protection on the outer radiators.
Good shout on the oil cooler grille - takes minutes to fit, and you don't need a ramp
      Today, 01:11 PM   #14
M271
M271's Avatar
48
Drives: BMW G87 M2
Mine is a '23 auto, but has the outer rads protected, so to speak.
Fitted the oil cooler, took all of ten mins, and that includes jacking the car up.
Photo of the fitted cooler, and the left/right rad protection in place.
Size:  1,014.4 KBName:  IMG_7232.jpeg
