BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      11-30-2024, 01:13 AM   #1
YourName
Drives: 2024 BMW M2
Are front caliper bolts really single use?
Hello, ive seen a couple comments that the front caliper bolts are single use. Can anyone confirm? My m2 has about 2k miles and switching to ebc red stuff and given its brake-related just want to be extra sure…
Would also be interested in confirming torque values for the 2 bolts on both the front and rear calipers. From what ive seen both bolts on rear are 35nm and front is 130nm but have seen varying comments. There was a post that has a ton of torque specs for the calipers. I just was unsure which component represented the two bolts
Thanks!
      11-30-2024, 07:46 AM   #2
nripin
Drives: g87 m2
Following
      11-30-2024, 10:51 AM   #3
M2M3M3
waiting....
M2M3M3's Avatar
72
Drives: 95 M3, 97 M3
97 E36 M3/4/5  [0.00]
95 E36 M3  [0.00]
They may be nuts, not bolts.
Reusable either way. Just use a dab of locktite.
Kudos for doing this yourself! Ez job!
      11-30-2024, 08:08 PM   #4
ZPD
ZPD's Avatar
686
Drives: 2022 M850i GC, 2023 G87
The nuts are single-use. They utilize a deformed thread as a locking mechanism. Once the nut is backed off, the deformed thread is "undeformed" and behaves like a regular nut. I wasn't aware of the deformed nut and reused mine after my first pad change and one of the nuts came off while on track. I would recommend getting a new set. The stock nuts have a somewhat thin wall. You can get beefier deformed nuts for less $ from McMaster Carr if you like.
Loctite is an option as well; but I would still go for a thicker nut. Don't use nylon locknuts; your brakes get too hot for nylon to be effective.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
      11-30-2024, 10:26 PM   #5
YourName
Drives: 2024 BMW M2
Thank yall. Ok i will likely do locktite as a stop gap for now
M2M3M371.50
      12-01-2024, 12:46 PM   #6
JABCAT
Professor
JABCAT's Avatar
4405
I replaced the brake pads at 500 mi & reused everything. I have over 17,000 mi now & no issues with the caliper bolts/nuts.
M2M3M371.50
      12-02-2024, 01:39 PM   #7
Sleeper
Sleeper's Avatar
Drives: 2023 X5M, 2024 M2, 2006 M3
For the small cost and huge peace of mind, I swap new caliper nuts each time I swap pads. Not f'ing around with braking. The chance of something happening is probably close to 0, but if it did, the downside would be pretty aggressive.
      12-02-2024, 02:43 PM   #8
YourName
Drives: 2024 BMW M2
Do you have the part number please?
      12-02-2024, 02:45 PM   #9
YourName
Drives: 2024 BMW M2
Think this is it. https://www.bimmerworld.com/Brakes/C...xoCse4QAvD_BwE
      12-08-2024, 02:32 PM   #10
Sleeper
Sleeper's Avatar
See the highlighted line in the image.
