12-01-2024, 08:59 AM | #1 |
Christmas Poo
1660
Rep 1,418
Square Winter Setup - 275/35 19s
Posting this here for anyone searching, but put on my winter tire setup setup and it drives well.
- Nokian Hakkapeliitta R5s 275/35 19 square setup on a square wheel setup - Stock front 19” 930M rims all around, I picked up a couple front rims in the classifieds section - No spacer in the front (it will rub with a spacer if lowered like me) - 10 mm spacer in the rear (no rubbing without it, just don't want it too tucked as I'm running a narrower rim and tire than stock) - MP HAS lowering springs down almost the entire way (1 full turn up) - Rims and tires are nicely tucked so they don't throw as much stuff down the side of the car
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
12-01-2024, 09:38 AM | #2 | |
Rep 1,451
Mr. Hankey1659.50 |
12-01-2024, 10:01 AM | #3 | |
Christmas Poo
1660
Rep 1,418
Since I have a dedicated set of summer rims, I figured it was easier (and cheaper) to just run 19s all around for winter and picked up a set of front rims for the rear so I can run a true square set up, Without stretching the 275 on a 10 1/2 inch rim and have a slightly more compliant tire out back for winter frost heaves. I think this is the set up I should’ve had for the eight years I had my M3, although I never had a problem with that.
Ronin761555.00 |
