BMW M2 Forums 2023+ (G87) Marketplace Classifieds Sponsors Classifieds
      12-02-2024, 04:30 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
10064
Drives: G82 M4 / G87 M2
IND | MMX Performance G87 M2 Adjustable Sway Bar Link Sets
MMX sway bar end links (drop links) replace the soft factory rubber bushings and their weak plastic bodies with these beautifully engineered adjustable aluminum billet replacements. Designed with one aim in mind: to help achieve optimum suspension performance and geometric accuracy, and thus increase the effectiveness of your anti-roll bars.
Fully adjustable to zero the pre-load on the anti-roll bar geometry. Our clever design means that adjustment can be carried out at both ends whilst the drop links are installed, making neutral positioning much easier.
Each heavy-duty, high-articulation drop link attaches the anti roll bar ends to the struts up front and the lower suspension arm in the rear. Replacing the failure-prone, weak OEM links with our rigid billet aluminum links with motorsport-spec ball joints greatly reduces flex and allows a sharp, uncompromised transfer of suspension movement through to the sway bar.
Product Details:
  • Manufactured from Aircraft grade T6-6061 aluminum billet
  • Complete OE replacements
  • Our single threaded ends make for easy length adjustment while installed
  • Anodized in signature MMX Gloss black
  • Heavy-duty ball joints to ensure a long life span
  • Can be used with either factory or Aftermarket rear anti roll bar, and returned to standard at any time
  • Rubber boots for longevity and durability.
The MMX Performance G87 M2 Adjustable Sway Bar Link Sets may be viewed at the following links to our website:
Front: https://ind-distribution.com/product...y-bar-link-set
Rear: https://ind-distribution.com/product...y-bar-link-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
