      12-03-2024, 10:42 PM   #1
Potato Head
Drives: None Yet
What body panels do we share with the m240i?
I’m guessing the trunk, door and hood are the same? Are the fenders also the same? The rear fenders on the 240 seem to share similar chonkiness?
      12-03-2024, 11:17 PM   #2
aerobod
Car Geek
aerobod's Avatar
No, they aren’t the same, the M2 is 1887mm wide without mirrors, the M240i is 49mm less at 1838mm, due to the narrower fenders.
      12-04-2024, 12:19 AM   #3
Potato Head
Drives: None Yet
So not even the rear fenders are the same?
      12-04-2024, 12:37 AM   #4
aerobod
Car Geek
aerobod's Avatar
No, the whole body pressing that includes the rear fender is different:
G87 - https://parts.bmwnorthwest.com/p/Bmw...008086503.html
G42 - https://parts.bmwnorthwest.com/p/BMW...009622065.html
      12-04-2024, 06:55 AM   #5
IanH
Drives: '25 M240xi
Hood and trunk only shared parts. Doubt the doors are the same even if they look similar.
2025 M240i Xdrive TNM/Cog
      12-04-2024, 04:18 PM   #6
techwhiz1
techwhiz1's Avatar
2534
Drives: 2023 i4 M50
No.
It's a different car.
G42 vs G87
I'm not sure if any exterior parts are the same.
Some interior parts are.
2023 i4 M50 - Tanzanite II, Individual Full Tartufo, 20" wheels, all options, PPF, ceramic coating, tinted, lowered (Eibach)
      12-04-2024, 04:25 PM   #7
aerobod
Car Geek
aerobod's Avatar
They are the same part on all G87 and G42s, 41009466299 for the left door 41009466300 for the right door.
      12-04-2024, 04:30 PM   #8
IanH
Drives: '25 M240xi
Woulda thought for sure that the wide body negated that. interesting.
      12-04-2024, 04:47 PM   #9
aerobod
Car Geek
aerobod's Avatar
It is really all in the sills / rocker panels. The core structure and doors stay the same, but the sills are extended out to reach the wider fenders. Probably a significant production cost saving, as all the door hardware and some trim panels can be the same, with just a change to the mirrors and part of the door card insert.
      12-04-2024, 08:20 PM   #10
kudos
Drives: BMW M240i
The hood and trunk are the same.
E90
      12-06-2024, 01:10 PM   #11
Saigonheat84
Drives: 2014 bmw 328i, 2024 bmw m2 g87
door are same
      12-06-2024, 01:15 PM   #12
MineralGreyMetallic
MineralGreyMetallic's Avatar
1100
Drives: 24 BGM M2 6MT
Those separate body panels are welded together, right?
      12-06-2024, 03:29 PM   #13
aerobod
Car Geek
aerobod's Avatar
They supply the side section as a whole (panel #1, as fitted on the production line), or as separate sections for selective repair (panels 2 & 3, with repair pieces 4,5,6).
      12-07-2024, 09:28 AM   #14
MineralGreyMetallic
1100
I've always wondered about this ...
Wouldn't it always be easier to replace the entire panel (#1) instead of buying a section and having to weld? By easier I mean less risk of misalignment or other issues at the weld point.
      12-07-2024, 11:11 AM   #15
aerobod
Car Geek
aerobod's Avatar
It is less disruptive to the other components it is attached to if a partial section is used, as lots of spot welds and body sealer will need to be removed to replace the full panel. In some cases only part of the repair panel may be used, too (depending on BMWs allowed repair procedures, I expect) to minimise the amount of original bodywork that is replaced.
