12-08-2024, 10:52 AM | #1 |
![]() ![]() ![]() ![]() 1265
Rep 939
Drives: 2024 BMW 230i xDrive
First World Problem - Cold Steering Wheel Trim
This is definitely a first world problem, but when using my heated steering wheel my hands still end up very cold as they make contact with the unheated trim piece.
Has anyone figured out a workaround for this ![]()
This post sent using 100% recycled electrons.
12-08-2024, 12:37 PM | #3 |
Rep 939
Kind of defeats the purpose of the heated steering wheel
12-08-2024, 12:41 PM | #4 |
Rep 24
Don’t have a solution for you but did want to comment that in my opinion the heating with the steering wheel is weak.
Have the alcantera wheel, first time so no idea if that effects the heat intensity. That said I’m a Houston boy living in Dallas so more than soft when it relates to cold weather… |
12-09-2024, 10:35 PM | #5 |
![]() 2050
Rep 2,238
My hands do not touch the trim long enough to be bothered by it. Quick tap of the volume or next track button isnt doing anything. I love the heated steering wheel and how it comes on automatically on cold days along with the heated seats. Granted, my car stays in the garage overnight so my mornings are not bad.
12-10-2024, 01:16 AM | #6 |
![]() ![]() ![]() ![]() 1033
Rep 569
Drives: BMW G87 (2024),BMW E82(2009)-s
Had same issue the other day. Part of the sw was freezing cold.
Even if I live in LA, need to be more careful to the touch since cold surfaces trigger my Raynaud’s attacks. |
12-10-2024, 10:45 AM | #7 | |
Rep 939
Now I could the wheel in a different position, but the thumb indents are there precisely for you to position your hands there ![]()
12-10-2024, 01:47 PM | #8 | |
![]() 2296
Rep 2,748
M2M3M3365.50 |
12-10-2024, 02:24 PM | #9 | |
Rep 939
10 & 2 was what was taught back in the 70's when I learned to drive, but has long since been replaced by 9 & 3.
12-11-2024, 09:09 AM | #11 |
Rep 939
Yep, my last one!
12-13-2024, 05:57 AM | #12 |
![]() ![]() 51
Rep 218
If the majority of your hands are on the heated leather portion and a small part of your hand rests on the trim then how do your hands end up very cold. The trim might initially feel cold (I tested yesterday to consciously hold the wheel as you describe and confirmed) but in a very short period the heat going to the rest of your hand transfers through your hand to the trim. At 33 degrees outside temp, I found my hand no longer detected any cold at all within about 90 seconds. So basically I’ll give the dealer response and say I can’t replicate your issue. I also don’t see why you’d hold the wheel that way, as 9 and 3 is a position I use the majority of the time and my hands are essentially 100% on the leather covered part of the wheel. Maybe try rotate your hands outward to be around the outside of the wheel more.
12-25-2024, 12:43 AM | #13 |
![]() ![]() 367
Rep 321
I notice this also on our G42. One thing that would help is replacing the aluminum trim with one of the carbon options. Our G83 has the CF trim and you really do not notice this piece as being cold with its lower thermal conductivity.
