12-27-2024, 11:22 PM | #1 |
Rep 202
Track rats and spring rates
Track rats chime in. Figure something like this could help others as they start their builds
Suspension setup : mcs one ways , some spl bits Spring rates: 700f /1000r Divorced rear? Yes Tire tread wear: 100 Aero?: stock How’s the car feel? Excellent on street but a little soft on fast tracks. Rear is basically bottomed out or tucking rear tires. Going to be jumping up rates to 900/1200 Example pic of my rear tucked in an off camber turn at cota |
12-28-2024, 04:27 PM | #3 |
Rep 202
Packaging tightness and clearance from swaybar and other bits Some setups non divorced can have tight clearances or even rub the spring in non divorced setups (pretty common with Supras). Divorced keeps the same as stock layout and leaves a lot of room around the strut body. This also keeps the load path the same vs putting it all on just the shock tower , though, no one has seen an issue with that im aware. Just preference. You can also run lower spring rates on rear of a non divorced setup.
12-29-2024, 02:52 PM | #4 |
Rep 395
Suspension setup : mcs 3-ways, a bunch of SPL stuff
Spring rates: 800f /700r Divorced rear? nope- happily married Tire tread wear: 200 Aero?: Adro rear wing, Verus splitter How’s the car feel? Nice and tight on the street. I can't imagine it being better on the track but perhaps I will wait to see what you do. I will let you be the guinea pig on spring rates
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, SPL links, Adro wing, IRL exhaust, Verus Splitter, MAD downpipes, Bootmod3; IG:g87_43 |
sly1types469.50 |
01-02-2025, 12:57 PM | #5 |
Rep 174
My car will be in production in couple of days, but most of parts already ordered or delivered.
Suspension setup: Moton 3-way with Dual Digressive pistons, Suspension Secrets full kinematics kit and H&R sway bars Spring rates: F 170 N/mm, R 140 N/mm Divorced rear: No Tire tread wear: 80-140 Aero: AeroDynamics GT-track wing, SpeedEngineering splitter Can’t wait to build it and race it
2009-2011 E90 320si street/track car - SOLD ; 2010-2016 E92 330d LCI street car - SOLD ; 2016-2018 F30 335d LCI street car - SOLD ; 2011-2021 E46 M3 track car - SOLD
2018-2024 F87 M2 Competition street/track car - SOLD ; 2021-???? 1986 E28 M535i show car ; 2025-???? G87 M2 street/track car My Instagram Last edited by Vojta89; 01-02-2025 at 01:43 PM.. |
M2M3M3203.50 |
01-11-2025, 07:56 PM | #7 |
Rep 202
