      12-29-2024, 12:11 PM   #1
elprincep
Drives: BMW m240i
Factory warranty with exhaust modification
I have the car under warranty, and tomorrow I'm going to BMW to fix some vibration issues I have inside the cabin (from what I've seen here, I'm not the only one). The thing is, I already changed the exhaust and the downpipe (using anti-failure sensors, I haven't touched the ECU). Will the warranty cover the vibration issue or not? What do you think? The exhaust has nothing to do with the problem I have...
      12-30-2024, 08:03 AM   #2
nripin
Drives: g87 m2
      12-30-2024, 08:03 AM   #3
nripin
Drives: g87 m2
Can you please link me to the anti-failure sensors you used?
      12-30-2024, 09:52 AM   #4
elprincep
Drives: BMW m240i
Name:  Captura de pantalla 2024-12-30 155023.png
Sure. They are LEIB OPF sensors. Not cheap but it should be good quality. No problems until this moment. You would need these two things:
      12-30-2024, 05:03 PM   #5
Chapman_Barnett
Chapman_Barnett's Avatar
Drives: 2023 bmw m240i
It all comes down to the Magnuson-Moss warranty act. BMW cannot deny the warrenty unless they can prove that your modifications caused that problem. The easiest way to think of warranty stuff is this. If your headlight stops working they can’t blame it on your exhaust mods. And if they try to do this I would highly recommend finding another dealership and build a relationship with them!
      12-30-2024, 09:45 PM   #6
M_Power Rob
Drives: '23 M240 and '23 M2
Exactly...a rattling noise from the undercarriage, that's a different story.
I took my G87 M2 in for it's run-in service with the Valvetronic valved sport exhaust system (catback) and they said nothing. I am now fully built custom Stage 2 tuned, trans tuned, downpipes, the exhaust, intake, colder plugs, aftermarket heat exchanger and oil and trans coolers and I would be very hesitant to take it to BMW for repairs (although I do have a connection so I could take it in if needed).
      12-31-2024, 08:59 AM   #7
IanH
Drives: '25 M240xi
OP is in Spain guys, Magnuson who?
2025 M240i Xdrive TNM - Dinan Springs - CF Goodies - More in process
m3619.50
      12-31-2024, 02:59 PM   #8
elprincep
Drives: BMW m240i
Well, guys, they didn’t want to take a look at it. They sent me a video saying the vibrations are caused by the Milltek exhaust (NO). They told me to put everything back to stock and come back...
I don’t know what I’ll do because, honestly, even if they take a look at it, I have little hope they’ll fix anything. I have the same problem many others have: excessive vibration from the right speaker when accelerating in sport mode WITH the iconic sounds activated. On the other hand, there are also some minor vibrations.
      12-31-2024, 03:40 PM   #9
kudos
kudos's Avatar
265
Drives: BMW M240i
Try turning iconic sounds off and see what happens. If you have aftermarket exhaust I wouldn't want iconic sounds on anyway.
E90
      12-31-2024, 04:49 PM   #10
elprincep
Drives: BMW m240i
When i turn of iconic sounds, the vibration disapears. I dont want fake sounds through the speaker but iconic sounds also opens flaps... I guess this can be changed if I flash the ecu.
Who thought it would be a good idea not allow the drive to turn off the fake sound without the need to close flaps...?
      12-31-2024, 05:52 PM   #11
IanH
Drives: '25 M240xi
Get bimmercode. Turn off iconic sounds (just the sound part, there's a thread about this) and then leave iconic sounds enabled in menu.
Dongle + app you are looking at about $85
      12-31-2024, 07:30 PM   #12
elprincep
Drives: BMW m240i
yeeeah that is a good idea, Ill probably do that.
