12-31-2024, 08:41 PM | #1 |
Rep 437
Just to confirm- 315s will fit
I have a set of PS4S 315/30 from my old C8 that I want to put on the G87
I was told in another thread that they should fit but wanted to confirm that before taking them to get put on |
12-31-2024, 08:59 PM | #2 |
Rep 3,862
Crazyotter369.00 |
12-31-2024, 09:01 PM | #3 |
Rep 437
12-31-2024, 09:11 PM | #4 | |
Rep 3,862
Yeah, I know it is in the extreme range but you can run into issues with handling, tire wear, sidewall rollover and potentially failure. Can't comment on contact issue with suspension. These issues can be exacerbated depending on what tire it is. I am running 305/30/20 on a 20x11 rim. Last edited by M_Power Rob; 12-31-2024 at 11:25 PM.. |
Ronin761689.50 Crazyotter369.00 |
12-31-2024, 09:12 PM | #5 | |
Rep 437
12-31-2024, 09:43 PM | #6 |
Rep 3,862
TBH, didn't put any miles on the stock tires. Car was taken by enclosed trailer from the dealership to shop where rims went on and 305s. I have gone through two sets of drag radials and now running Cup 2s. I need every bit of ture I can get as I am tuned to 740whp (I would be running 315s but it would be too close to rubbing under certain conditions). |
Crazyotter369.00 |
01-02-2025, 02:31 AM | #8 |
Rep 121
The car is significantly more planted with the 305. Our cars need as much rubber under them as possible to combat the weight. I recently did tire testing on 265/35/18 MAXIS 200tw and it was hilarious. A ton of fun, but definitely not as fast as a 295/305
I wouldn't do 315's on anything smaller than a 11 inch. Over sized rubber as Rob brought up can have issues. I think grass roots motorsport did an article on multiple sizes on multiple wheel set ups (275/285/295 on a 10/10.5/11). These aren't the actual sizes but basically it turned out that a slight stretch performed "better".
@DutchBoysRacing
Crazyotter369.00 |
01-02-2025, 04:40 AM | #9 | |
Rep 437
I knew the 315s probably wouldn’t work but I was just hoping someone would say that they would since I already have them sitting in my garage |
01-04-2025, 09:20 AM | #10 |
Rep 437
So I’ve come to grips (no pun) that the 315s won’t fit, but I still want to upgrade so I’m going to get new wheels (20x11 rear) and put 305s on them.
My suspension is stock. Will 305s fit perfectly or will I need spacers? |
01-04-2025, 09:36 AM | #11 | |
Rep 3,862
305s on 20x11 rims with the right offset will be fine (no spacers). I am running them and lowered on Ohlins Road and Track coilovers. With my setup 315s will not fit. With the right offset in 20x11 rims, and depending on ride height, you should be able to go with the 315s (others have done it). This may be a stupid caveat but I am talking rears only |
Crazyotter369.00 |
01-04-2025, 10:36 AM | #13 |
Rep 3,862
01-04-2025, 10:40 AM | #14 | |
Rep 437
I was thinking about these so far https://www.forgelitewheels.com/product/fl1 https://www.vtforged.com/store/p84/R...-WHEELS.html#/ |
01-04-2025, 10:54 AM | #15 | |
Rep 3,862
I am not familiar with Forgelite. For the VT, reach out to AndyVTForged to discuss offset and fitment for the 315s. |
Crazyotter369.00 NewToM1749.00 |
01-04-2025, 10:59 AM | #16 |
Rep 437
01-04-2025, 07:33 PM | #17 | |
Rep 437
My plan is 20x10 front with 285/35 21x11 rear with 305x30 Look good? |
01-04-2025, 10:14 PM | #18 | |
Rep 3,862
With those sizes you will most likely need to modifo the fender liners in the fronts. I have 20x11 with 305/30/20 on rears and 20x9.5 with 275/30/20 on fronts. |
01-04-2025, 11:49 PM | #20 |
Rep 3,862
01-06-2025, 12:03 AM | #21 | |
Licensed Professional Slacker
1922
Rep 1,100
Drives: 2024 M2 and 2025 i4 M50
The 305/30/20 rears would be approx 27.2" tall. I don't think the fronts would look good at all.
2024 M2 and 2023 Mazda CX-30
01-06-2025, 12:07 AM | #22 |
Rep 437
