BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      01-03-2025, 04:36 PM   #1
LA2912
Drives: On Order: BG G42 M240i xdrive
Lowering springs question
I'm due to take delivery of my M2 in the next couple of weeks and looking at the suspension setups available. I'm looking at the Eibach pro kit which states drop rates as follows... Front 15-20mm | Rear 10-15mm.
I already have a set of spacers from my G42 which will fit, which will be ran as 15mm front at 12mm on the rear.
Has anyone ran a similar set up and are there any rubbing issues? If so, how are they rectified.. thanks
sycd260.00
      01-03-2025, 04:40 PM   #2
Dave07997S
Dave07997S's Avatar
1462
Drives: 2024 BMW M2 Toronto Red 6MT
My car with Eibach Pro Kit (US Version) and 15mm spacers all 4 corners. There is some rubbing on full lock in reverse only in the front. I took some climbing chalk rubbed it on the vents and saw where it was rubbing. I proceeded to take a dremel tool and grinded down the offending vents to now its a very slight rub...I will go back in there later and do some more grinding.
A few picx for you with 295/30/20 Yokohama V107s out back.
(Sold) 2020 Ford Mustang GT 6MT PP1 444rwhp
2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk, 2001 BMW M3
sycd260.00
zjldmd101.00
      01-04-2025, 09:26 AM   #3
Ronin76
Ronin76's Avatar
Drives: 2018 Tesla Model 3
I love the rear view pic of those 295 tires. I was planning on doing 285 in the front and 305 in the rear and looking at your tires I can’t wait!! Nice setup!!
sycd260.00
Dave07997S1461.50
      01-04-2025, 12:00 PM   #4
sycd
sycd's Avatar
Drives: G87 M2 [MT]
Dave07997S this looks sharp and the way your car came out was one of the reasons why I just ordered a set of Eibach springs. I also ordered spacers for 15F/12R. Just in case there is rubbing, I also have a set of modified liners on order, so I don’t have to alter my stock ones. I’ll share some pics once it’s all installed.
Dave07997S1461.50
      01-04-2025, 12:46 PM   #5
AZG87
Drives: G87, 2018 Mustang GT traded in
I ran 12mm spacers front / back with port installed MP HAS max drop. 0 rub. I swapped to 19x10 +11 and 20x11 + 8 wheels on oem ps4s stretched no spacers no rub. Swapped to 285/35 in front and 305/30 rear, fronts would have rubbed with that setup but opted for the R44 fender liner clearance kit first so no rub either after going wider.
sycd260.00
Dave07997S1461.50
      01-04-2025, 04:07 PM   #6
Dave07997S
Dave07997S's Avatar
1462
Are you going with those sizes on the OEM wheels? I wouldn't go beyond a 275/295 setup on OEM wheels. However, thanks for the kind words!!
      01-04-2025, 04:26 PM   #7
Ronin76
Ronin76's Avatar
No, I am getting aftermarket…10” front 11” rears
Dave07997S1461.50
AZG871302.50
      01-04-2025, 05:59 PM   #8
Dave07997S
Dave07997S's Avatar
1462
Yea, when I finally switch out thats the sizes I am running. I had similar sizes on the Mustang.
Ronin761689.50
AZG871302.50
      01-04-2025, 09:35 PM   #9
Dave07997S
Dave07997S's Avatar
1462
Some people still rubbed even with the 12mm up front.
