      01-04-2025, 05:30 PM   #1
EUPremier
Ireland
416
Drives: 2025 G90 M5
Road salt & underbody-corrosion-prevention
Anyone who does a bit of engine-powered boating on salt water is likely familiar with the salt antidote, ‘Salt Away’.
It’s a flushing & rinsing detergent that defeats existing salt & leaves a salt-resistant film on all manner of objects.
I have used it on jetskis and trailers and have found it excellent. It’s biodegradeable and made of all sorts of lovely stuff according to the manufacturer.
I was thinking it would be ideal for wintry-conditions when roads are being salted resulting in underbody corrosion.
My plan is to use an underbody lance to rinse the car with a Salt Away solution, see images.
I wonder has anyone thought about doing this or whether someone already is and whether it’d be unkind to the complex undercarriage of G9x?
Currently driving 2016 F10 M5 & 2017 G11 730d.
Note: Taxes on vehicles in Ireland are bananas!
Previously
2019 G05 X5 M50D, 2016 F36 430d, 2012 F10 520d, 2006 E60 M5, 2005 E60 530D
MoeTE871326.00
      01-04-2025, 08:31 PM   #2
carbonfiber1
Drives: 2025 M5AlpineWhite\Silverstone
That’s awesome where do you get it Amazon ?
      01-04-2025, 08:58 PM   #3
EUPremier
Ireland
416
Drives: 2025 G90 M5
Yes, I think car heads have been missing a trick with this and the boaters have kept the benefits to themselves.
It appears to be pretty much everywhere.
Good stores that sell boating equipment likely stock it. We call call those stores ‘Chandlery’ shops but Amazon is certainly an option.
Advise you stick to the ‘Salt Away’ brand. There are a few copy cats that may be amazing but I have no experience of them.
Be sure to buy the ‘kit’ initially… it comes with the doser you’ll need to attach to your garden hose (it won’t handle the jet washer pressures directly).
My plan is to feed my jetwasher via the garden hose with the Salt Away doser inline the feed side. Then hit the undercarriage using the special lance.
Simple enough setup that should deliver a corrosion-free car for the long run.
Previously
      01-07-2025, 03:01 PM   #4
EUPremier
Ireland
416
Drives: 2025 G90 M5
I treated mine this evening. Took about 30mins to sort the hoses to put Salt Away through the pressure washer but easy to repeat now.
Can’t hurt.
Previously
MoeTE871326.00
E46ZHP258.00
      01-08-2025, 01:46 AM   #5
imperfectluck
imperfectluck's Avatar
544
Drives: 20' F87
Well I’ll be damned, I’ve been looking for something like this in the north east of America as when they plaster salt on the roads, it’s one of the few times I drive the beater vehicle to avoid the salt corrosion.
The sprayer on wheels Is a win in terms of application of the product. Will look to pick one up and keep us posted on the results
      01-08-2025, 03:12 PM   #6
EUPremier
Ireland
416
Drives: 2025 G90 M5
Lol, thanks for chiming-in, the thread has garnered much interest… I thought perhaps my OCD had gotten the better of me!
In terms of posting results, it’s going to be a long time before the effort can be proven to bear fruit. We don’t get really bad winters in Ireland so it’s only occasionally the councils send the gritters out.
I’m working off the basis that salt is bad for cars and Salt Away is a proven, harmless product. It worked great on my boats.
In all reality, I’m doing this for future owners and corrosion won’t be an issue for a pre-purchase inspection.
By the way, I also used the regular lance to hit the wheels /brakes with a gentle mist of Salt Away solution.
Let me know how you get on too and I’ll post any further updates here.
Previously
      01-09-2025, 01:24 PM   #7
Oswiff
Oswiff's Avatar
Drives: 2021 m5 comp
I bought one by Ryobi from Home Depot many years ago. It works so long as your pressure washer wand is long enough to reach the middle of the car. Mine wasn't so I had to buy an extended wand.
Anyhow, it does the job. On amazon now.
https://www.amazon.com/Ryobi-Pressur...35179298&psc=1
      01-23-2025, 01:48 PM   #8
starlights
Drives: G05 50i
Any negative impact of Salt Away on the paint?
Does it require to be rinsed?
Ordered one but until the temp gets above freezing won't be using it for undercarriage wash, only hand held air pressure pump (think garden sprayer) for washing off the white salt off the body and bumpers.
      01-23-2025, 03:44 PM   #9
EUPremier
Ireland
416
Drives: 2025 G90 M5
I started using Salt Away on Jetskis in 2012. The gelcoats were painted and I never had any negative results.
It was great for preventing salt corrosion or, at least, I didn’t get any on the new ski I treated from Day 1 which was used exclusively in salt water.
It’s made in America and the mnfr. claims it’s a completely benign formulation. They list an endless range of applications including automotive.
They further claim that leaving it on is best as it leaves a ‘film’ which inhibits future salt attack & rinsing off is only required in limited cases.
I honestly don’t believe it’ll hurt the vehicle.
With all that said, I’m tending to keep my G90 off the road when there’s bad weather and/or salt-spreaders are active.
Previously
      01-23-2025, 03:50 PM   #10
Yuille36
Yuille36's Avatar
Drives: X5M, M3 ZCP 6MT, MB E63 AMG
2015 BMW X5M  [9.87]
2017 BMW/M3  [9.92]
I'm headed to my local touchless car wash, right after work to get the nasty salt off my F85 X5M.
I have been really good at keeping the salt off, but with the temperature so low these last 10 days or so, my car wash has been closed with temps in the 20's.
The F80 M3 and W211 E63 AMG have been tucked away in the garage away from all this salt.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
EUPremier415.50
      01-23-2025, 04:42 PM   #11
starlights
Drives: G05 50i
Its still below freezing in DMV - once you drive off the cold air will freeze any remaining water in places it did not completely blow dry in the carwash.
      01-23-2025, 04:52 PM   #12
John in VA
Drives: 2015 228i M Sport
I'm headed to my local touchless car wash, right after work, to get the nasty recycled salt water from all the other cars sprayed onto my F85 X5M.
Fixed that for you!
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      01-23-2025, 06:26 PM   #13
Yuille36
Yuille36's Avatar
2015 BMW X5M  [9.87]
2017 BMW/M3  [9.92]
Yes, I'm aware of the temperatures. But it so happens that the car wash lane was closed, so no washing my vehicle today, might have to wait until the weekend.
      01-23-2025, 08:03 PM   #14
EUPremier
Ireland
416
Drives: 2025 G90 M5
Nice carpark… if you lived in Ireland you’d have to pay the State €7,200 each and every year to have the privilege to drive the three of those on public roads. Not very petrolhead friendly here! 🙈
Previously
      01-23-2025, 08:05 PM   #15
EUPremier
Ireland
416
Drives: 2025 G90 M5
I’m not used to dealing with such low temperatures on a regular basis.
I’m gathering from the comments that washing a car in well-below-freezing temps is a bad idea, why is this?
Previously
      01-23-2025, 08:30 PM   #16
stbm5
Drives: 2018 M5 DG
Feynlab has an industrial coating for the underside.
EUPremier415.50
      01-24-2025, 08:31 AM   #17
starlights
Drives: G05 50i
Any residual water left in joints after washing that doesn't dry will freeze and expand....and therefore has a *potential to cause damage.
EUPremier415.50
