      01-05-2025, 11:39 AM   #1
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
Delivery 2025 M2 - "Replace Battery"
Looking for advice. I took delivery of my car after PPF a little over a week from initial pickup at BMW Fairfax. When I programmed the car with BMW Genius at delivery there were no error messages. It started right up and drove home fine, but the error message stayed. I hooked it up overnight to a CTEK but the error message persists.. It still started fine thus AM. Currently charging again. Any thoughts? Help? Snow storm coming and at least it is home in the garage. Is the battery just a regular car battery in the G87 M2, or is it some light weight Li battery or something? Any help is greatly appreciated.
      01-05-2025, 12:00 PM   #2
Bimmer Frank
Bimmer Frank's Avatar
78
Drives: VW GTI
2025 BMW M2 ordered  [0.00]
2012 VW GTI  [0.00]
It might be helpful to take a picture of the part number on the battery itself to see what you actually have.
It appears that '23 and '24 are AGM batteries, but perhaps '25 is different.
RMB278.50
      01-05-2025, 12:14 PM   #3
Tag
this is the way
Tag's Avatar
20452
Drives: N-1 starfighter
The battery in the M2 is AGM, not Li-ion. This sort of thing happens at shops when people working on the car leave the doors/trunk open. You can go for a long drive and then put it back on the tender to speed up the charging. If the errors don't clear bring it to the dealer to have a look.
NewToM1749.00
RMB278.50
wjones14919.00
      01-05-2025, 12:18 PM   #4
M_Power Rob
Drives: '23 M240 and '23 M2
This...and there have been other posts about this happening with ppf and tint installation.
NewToM1749.00
RMB278.50
      01-05-2025, 12:45 PM   #5
Carefree
Carefree's Avatar
Drives: M240i, M2
The battery in our 2024 was replaced 7 days after delivery due to failure.
No ppf, coating, tint, etc. services during that week, only normal use.
RMB278.50
      01-05-2025, 01:05 PM   #6
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
Thanks Tag. That makes a lot of sense. I appreciate your input. I will leave it plugged in on the CTEK non-stop now and I will see if that does it. I will also call BMW of Fairfax to check with them.
      01-05-2025, 01:06 PM   #7
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
Thank you for the reply and I greatly appreciate your input.
      01-05-2025, 01:08 PM   #8
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
I hope that I don’t have to do the same but I will check with the service department on Monday and see if I have to bring it in. It starts up fine and it drove back from PPF without any problems and that was about a 60 minute drive up to highway speeds. Thank you for your reply.
      01-05-2025, 03:48 PM   #9
M2M3M3
waiting....
M2M3M3's Avatar
Drives: 95 M3, 97 M3
97 E36 M3/4/5  [0.00]
95 E36 M3  [0.00]
i would also suggest getting a charger that is designed for AGM batteries.
RMB278.50
      01-05-2025, 04:07 PM   #10
DomMuc
DomMuc's Avatar
Germany
689
message wont go away until you register battery as replaced....
RMB278.50
      01-05-2025, 04:31 PM   #11
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
How do I register the battery as replaced?
      01-05-2025, 04:43 PM   #12
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
The CTEK Multi US 7002 charges AGM batteries.
      01-05-2025, 05:53 PM   #13
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
Here is a picture of the battery. I couldn’t find anything out in particular when I put in the numbers in a search or Clarios. I’m guessing it is an AGM battery?
      01-05-2025, 08:16 PM   #14
Bimmer Frank
78
Drives: VW GTI
2012 VW GTI  [0.00]
Interestingly that part number brings up a different part on search with some sites, but it does match the 92Ah indicated on your battery and would confirm the AGM:
https://bmw.oempartsonline.com/oem-p...ry-61215a40e29
RMB278.50
wjones14919.00
      01-05-2025, 08:52 PM   #15
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
https://bmw.oempartsonline.com/oem-parts/bmw-vehicle-battery-61215a40e29
Thank you for the follow up. I am going to call the service dept tomorrow and see if their is a way to eliminate the error message. It starts and runs perfectly and charges to full and holds the charge without the CTEK showing an error or fault. Hopefully it just had an error message when it was close to being drained on the BMW and the battery is actually fine.
      01-05-2025, 09:14 PM   #16
Bimmer Frank
78
Drives: VW GTI
2012 VW GTI  [0.00]
If you want to get a second opinion, you can go to your local auto parts store and they can wheel out a battery tester, this would indicate if there are any issues.
I agree with you that it's likely just an error message that doesn't clear by itself. It might even be able to be cleared with an ODB port error code reader, perhaps some of our more knowledgeable members might know this.
RMB278.50
      01-06-2025, 03:58 AM   #17
DomMuc
DomMuc's Avatar
Germany
689
with oem bmw diagnostic tools....
RMB278.50
      01-06-2025, 08:28 AM   #18
Bimmer Frank
78
Drives: VW GTI
2012 VW GTI  [0.00]
So this device says 'New battery registration' for example:
https://www.bimmerworld.com/Tools/Fa...-for-BMWs.html
Sort of what I had in mind.
Hopefully the dealer will simply do it for you as a courtesy.
RMB278.50
      01-06-2025, 08:38 AM   #19
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
https://www.bimmerworld.com/Tools/Fault-Code-Readers-Diagnostic-Tools/Foxwell-NT530-OBD-System-Scanner-for-BMWs.html
Thank you.
      01-06-2025, 11:49 AM   #20
Tag
this is the way
Tag's Avatar
20452
BMW constantly supersedes PNs with newer ones for many parts. Sometimes the parts are updated versions, but most are just new PNs because they've changed suppliers.
The bracket in your picture is blocking the section that says AGM. You can see it in this picture on the right side of the battery.
RMB278.50
      01-06-2025, 03:53 PM   #21
RMB
RMB's Avatar
279
Drives: 2025 BMW M2
Thank you Tag. You are always very informative and detail oriented. I greatly appreciate you taking the time to help me. I tried calling BMW of Fairfax and given the snow storm they said they can’t help me now. They were not very helpful. Maybe someone will call me back tomorrow.
      01-06-2025, 05:00 PM   #22
fzr100098
fzr100098's Avatar
242
Drives: 2025 M2
CTEK is junk - and battery tender isn't much better
Get an Optimate - you will thank me later, I've tried all of them over about 20 years
I keep an Optimate6 hooked up on my M2 at all times when it's resting in the garage, which is most weekdays. They are the BEST
BgsDks221.50
