      01-06-2025, 09:40 AM   #1
johnisccp
Drives: BMW X7 40i
Scratches on the Aluminum interior
Hi,
I have some scratches on the aluminum trim and wanted to know if there is a way I can easily remove it. I have seen someone say to use scottbrite red pad but wasn't sure. Does anyone have any suggestions? Thanks in advance.
      01-06-2025, 10:05 AM   #2
John in VA
Drives: 2015 228i M Sport
Easy - probably not. The aluminum is anodized so at best you can try to polish it. Replacing the piece might be easiest.
Go to https://realoem.com/bmw/select.do & enter your car info, go to Vehicle trim to find the BMW part #. You can then shop using that #. Many BMW dealers offer parts online at a 20% or more savings.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
Rob41122.50
Llarry23196.00
      01-06-2025, 10:12 PM   #3
Rob411
Drives: 2019 M5C
Is it satin trim exterior pieces or brushed aluminum interior?
If you do try to do something to it...whatever you do...do not make circular motions or motions against the grain of the metal.
Are they light scratches or deep scratches? If moderate or deep...likely the best way is to replace.
You may wish to check out:
How To Restore Brushed Aluminum
MaxVO2369.00
      01-07-2025, 10:27 AM   #4
MaxVO2
MaxVO2's Avatar
369
Drives: BMW M8 Coupe
****The above products and video are good. I've done some restoration work on brushed aluminum on older cars before. Light scratches are easy enough to work out - deeper ones are best just replacing the piece if still available. Anything can be fixed for the most part, but can require a LOT of effort and creativity. Raw metal vs painted is *much* harder to deal with as paint can hide a lot of flaws with some filler put in, etc..
There are also brushed panel inserts or sections that can essentially be stuck over the old pieces if they are badly damaged but it requires some expertise in cutting and fitment. When done correctly, it is very difficult to spot but is done on older vehicles, classics, etc.. long out of production.
Good luck.
      01-07-2025, 10:40 AM   #5
johnisccp
Drives: BMW X7 40i
Thanks for the input. I will take a look.
      01-07-2025, 02:14 PM   #6
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
I have a few small scratches in mine. I rubbed them (in the direction of the grain) with a dry MF towel and minimized them quite a lot. I'm wary of trying any harder methods as the grain on our m3 trim is considered "rougher" by BMW than the non M e9x trim or even e46 era, from my direct comparison. I didn't want to diminsh the grain.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      01-08-2025, 10:42 AM   #7
johnisccp
Drives: BMW X7 40i
I use the scotch brite maroon color seem to remove the scratches. Thanks all who responded.
