      01-10-2025, 07:52 AM   #1
aaasimmons
Drives: X5
Any BMW Electrician specialist in New York City ?
Keep getting battery discharge message pop up on dash took it to the dealer few times they said they could not diagnose the problem until I remove all my accessories I have stage one tuning air horn added speakers and the last thing was auto start then that’s when I started to have the issue
Now I find myself jump starting with portable charger every now and again very annoying
Thought it could of been a cold weather issue but it started before the temp started to fall in early November
      01-10-2025, 11:41 AM   #2
chefwong
Drives: X5
How old is the battery.
Have you charged the battery to full off a charger, let it rest....remove battery from vehicle and bring it to AutoZone/Pep for a Load Tester to see if the battery is still good.
You may have a parasitic drain based on what you have listed.....at $175-$200 a hr at the indy, to either remove said items or determine if you have a parasitic drain may run the meter on what you spend either way you go.
      01-10-2025, 09:48 PM   #3
aaasimmons
Drives: X5
Brand new battery from the dealer and they even did the reprogram
      01-10-2025, 10:14 PM   #4
Rich.Wolfson
Thaumaturge
187
Drives: 2014 M235i
Originally Posted by aaasimmons View Post
...auto start then that’s when I started to have the issue ...
Who ever installed the auto start should undo it. Then see what happens.
///Rich
      01-10-2025, 10:16 PM   #5
aaasimmons
Drives: X5
Had it removed or at least disabled but still the same issue
      01-13-2025, 12:28 AM   #6
Drewbkm4
Drives: 2017 bmw m4 zcp
Go to Greenlight Motorworks on utica ave.
