BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      01-15-2025, 10:22 AM   #1
middle101
Drives: 2024 BMW M2
Driver side seat issue when car is running
Curious if anyone else has the same issue or a possible fix. This is mainly a winter issue.
I start my car to warm it up and when I go let me kids in the back seat via the driver side the seat won't slide to the front when the handle is pulled, however it will when not running. The passenger side slides open when the car is running or not.
Car states "Drivers seat back not locked"
Is this a safety feature or an issue? Anyone have a fix?
Thank you.
      01-15-2025, 11:58 AM   #2
aerobod
Car Geek
aerobod's Avatar
This may be working correctly, but also may be due to seat calibration being required. In the manual for seat calibration it states "1. Press the longitudinal direction switch forward until the seat stops. 2. Press the switch forward again until the seat stops".
If you haven't applied the parking brake, it is also worth doing that to see if it changes the behaviour.
      01-21-2025, 02:24 PM   #3
KC87ZB
KC87ZB's Avatar
473
Drives: 2023 M2
2023 BMW M2  [10.00]
I bet it is a safety thing when the car is running so that the driver doesn't get squeezed. You can try with the parking brake engaged, that may help but I'm willing to bet the drivers seat stays locked out when the car is running.
2023 M2
2014 Triumph Trophy
