      01-19-2025, 10:27 PM   #1
SpaceGhost
Drives: 2024 740i xdrive
M2 button defaults to manual shift?
SOLVED! THANKS GUYS.
Apologies if this has been previously discussed. I searched and didn’t see the exact question. I also skimmed the owner's manual without success.
I finally have my M2 home and have a small issue.
The car defaults to manual shift mode when I engage my M2 button. This caused me to bounce off the rev limiter today. It was brief and I realized my mistake quickly and manually up-shifted. I doubt it caused any damage. Just not sure why it defaults to manual shift.
I have my M2 button set up as follows:
Engine: Sport Plus
Trans: Sport Plus
suspension: Sport
Steering: Sport
Brakes: Sport
M traction level 5
Is there another setting I am missing to get M2 to default to auto shift?
Also, I assume the default start up configuration can't be customized (ie starting with engine in efficient but steering and brakes in sport etc)? I know it can't default to M1 or M2 mode.
Thanks in advance.
      01-19-2025, 10:54 PM   #2
goa87
goa87's Avatar
i believe you may have put the Drivelogic / Gearbox in S1/2/3 (S being sequential). Try sticking it in D1/2/3 and it should auto upshift/downshift.
      01-19-2025, 11:11 PM   #3
SpaceGhost
Is this a setting in the M button set up?
I know how to use the gear selector to go from D to S.
I was just noting that it defaults to sequential when i engage my M2 button.
      01-19-2025, 11:50 PM   #4
JABCAT
Professor
JABCAT's Avatar
4850
Yes you set the transmission settings to either or both M buttons. My M1 is set to D2 & M2 to D3.
      01-20-2025, 12:01 AM   #5
SpaceGhost
Was just tinkering in the car and realized I had set the trans to S3 instead of D3. Did the settings real quick with the genius at the dealer and didn't realize my mistake.
Thanks for the guidance guys. I am sure this is just one of many stupid questions I will have.
      01-20-2025, 12:03 AM   #6
M_Power Rob
Drives: '23 M240 and '23 M2
There are some good YouTube videos about setting up your M buttons. Just make sure you are looking at ones with the iD8 or iD8.5.
