      01-27-2025, 12:07 AM   #1
BGM80
REP
19
Drives: 2025 X6M
CR Spotless DI Water System
Hey Everyone,
I'm going to go in on a CR Spotless DI Water System (portable) and had some questions.
It seems you really only need it for the final rinse off. I saw someone's setup who created their own bypass of the system, then change the controls to have it pass through the CR system for the final rinse. Alternatively, just thinking about connecting it before the rinse, or just leaving it on for the whole thing and change the filters more often.
Does the stainless steel inlet hose it comes with limit waterflow/GPM at all, or have no impact?
Thanks in advance!
      01-27-2025, 01:22 PM   #2
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
I went for a non CR Spotless DI system, but they're basically all the same. Using it only for rinsing saves resin, the resin only can remove so much stuff before you have to buy more. There's benefits to using it for other things, it helps keep your soap from spotting, prevents nozzle build up, etc... but using it for rinse is where the real benefit is.
Bypass wise... You can spend money for Ys and Ts and whatever... Or you can just put a pair of quick connects on and manually move it.
      01-27-2025, 01:45 PM   #3
Pheonix
REP
1,020
Drives: 2007 Z4 M Coupe 2012 e93 M3
2007 BMW/Z4MC  [0.00]
I built my own 3 stages DI water system! For some reasons, our water has low TDS (around 50) but has some discoloration so I do Sendiment-Carbon-DI. I retrofit the CR Spotless cart since I use the system to clean the House Windows and Solar Panels couple times a year.
I just use the Shutoff valves and T for bypass. The stainless steel hose appeared not to affect the flow! Also add a flow metter to monitor flow and total consumption.
I spent less than half the price of the CR Spotless.
You could tell the water before and after
One of the best things I purchased. Now I could wash the car anytime and don't have wait for the sun to go down and dont even blow/wipe the cars after unless I apply sacrificial detailer afterwards.
      01-27-2025, 04:17 PM   #4
TboneS54
YNWA
TboneS54's Avatar
REP
958
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
I find rinse only method to still leave spots later. I'm starting to move to spotless for more than just final rinse. I'll do most of the wash without it, but I'll incorporate it earlier, like when I wash off soap for the last time, apply a touchless sealant, for example, then a final rinse.
And I don't have bad water at all, TDS of 210 from the source here.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      01-29-2025, 12:23 AM   #5
BGM80
REP
19
Drives: 2025 X6M
That homemade system is pretty legit - really nice work on that. I got the CR system and think just putting some quick connects on it seems like an easy way to quickly attach it for the rinse phase. I think I just get a few standard 3/4 hose connects and that will work for each side.
Correct me if I'm wrong - if I'm using regular water for the tires and foam, to then quick connect in the DI system I'll need to turn off the water supply, mostly empty out the pressure washer/hose, then attach the DI System, then turn water back on for the rinse.
Also - when you're done washing and you turn off the water supply (hose) do you then run the pressure washer/DI system a little to drain out the system?
Thanks everyone!
      01-29-2025, 08:18 AM   #6
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
I don't think it's gonna hurt anything to use the water that's in the pressure washer after connecting the DI water. Use it on your wheels or something if it worries you.
You could get a little shutoff valve... Or you could be a caveman like me and just fold the hose up 2-3 times to stop the flow of water lol. A shutoff valve before the QC is the nicer option for sure
It seemed like people recommend leaving the DI system wet inside. I'm curious about this too though.
      01-29-2025, 08:26 AM   #7
CTPJ
CTPJ's Avatar
335
REP
62
Drives: BMW M2
Here's my homemade pressure washing station. Although the DI system looks like it came from CR Spotless, only the mounting bracket is from them (it was more substantial than any other ones I could find online). Everything else, other than the 3/4" PEX pipe (which I got at HD), was sourced from either Amazon or Ebay. Additionally, instead of using DI cartridges, I am using an adapter kit that allows me to pour a 1/4 cu ft of resin into each filter for more capacity. Currently, I have it set up with a quick connect to attach it to my garden hose but will be connecting it directly to my house water supply as my next project. I also have quick connections on my Active power washer and an additional HP hose so I can disconnect it and use it for other duties around the house.
      02-01-2025, 12:55 PM   #8
BGM80
REP
19
Drives: 2025 X6M
I've put together my CR spotless bypass. Some of the systems I saw online directly had the Y connect on the output, and they say you actually never have to touch those valves/controls.
In my head I think this mixes the tap with the DI water, but I'm guessing there is some chemistry/physics that avoid this? Or does it mix a bit but it clears quickly once you start using the DI water and turn-off the bypass (on input)?
Thanks,
      02-01-2025, 02:13 PM   #9
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
That is not how I would do it.
What you're doing here is trying to shove water into the DI system. Presumably, you have a similar y on the other end so there's nowhere for it to go directly out, so it's just all mixing around inside. So you're using up resin and not getting anything out of it of benefit.
If you added a shutoff valve between the Y and the DI system, it would work, you would never close the house side of the y, and close the shutoff at the Din and open the bypass portion of the Y to bypass it. I would duplicate the setup on the output side to
Just my take, I'm no plumber or hydraulic engineer.
      02-03-2025, 11:52 AM   #10
BGM80
REP
19
Drives: 2025 X6M
Yeah, I thought the exact same thing as you blkGS. But even when I look at CR Spotless' own bypass system (link below) this is how it's set up. The outlet bypass only has the Y connector. Maybe there is something I'm missing, but I just think when the tap is active it somehow mixes when pushing through the output Y which has to be fully open.
https://crspotless.com/products/bypa...l&_ss=e&_v=1.0
      02-03-2025, 01:11 PM   #11
V1_ROT8
REP
25
Drives: 2018 340i xDrive 6MT
Pretty easy and cheap fix, though: just add one of these at the outlet of the DI system before the “Y”:
https://a.co/d/bCtAEqa
      02-03-2025, 01:26 PM   #12
CTPJ
CTPJ's Avatar
335
REP
62
Drives: BMW M2
Here are the assemble instructions
      02-03-2025, 02:24 PM   #13
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
Personally I'd put one at the inlet and one at the outlet. They're cheaper than buying new resin
      02-03-2025, 04:28 PM   #14
Portimao Blue M440ix
Portimao Blue M440ix's Avatar
REP
176
Drives: Bmw m440i g22 Bmw 335i e92
I would also add the shut offs before and after as well.
I wonder if there is a check valve on the exit side and thats why the factory set up is the way it is? Its definitely cheaper to add the shut offs to be safe then sorry when buying resin.
      02-03-2025, 08:15 PM   #15
txmav
REP
83
Drives: 335i (sold); 2022 X5; 2022 M2
Before buying your DI system, please check the specs for it. The performance for some DI systems really degrades (higher TDM) if the input flow rate is too high, and some pressure washers require a certain amount of input flow rate to work properly. Hence, you will want to make sure that your DI system can handle the flow rate needs for your pressure washer.
      02-04-2025, 02:21 AM   #16
monkeytail
monkeytail's Avatar
REP
19
Drives: BMW X3 F25
Thank you
      02-04-2025, 01:56 PM   #17
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
Valid point.
I bought a small spotbye system, it didn't state it's GPM rating. I looked at a few others that had built in flow limiters to ensure they could keep up.
IMO, a system with 2.5x10" canisters is unlikely to keep up with much and is only useful if you're filling a tank. The 4x10s may work if you aren't using a super high flow pressure washer. A pair of 4x20 housings like cr spotless uses should keep up without an issue.
      02-04-2025, 03:15 PM   #18
Pheonix
REP
1,020
I tested the CR Spotless (dual Cartridge model) and the flow was around 5.1 GPM. My special setup of 3 Cartridges yields about 4.1 GPM. The Active 2.0 requires about 1.8-1.9 GPM so plenty of flow.
CTPJ334.50
      02-04-2025, 03:34 PM   #19
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
What's your 3 cartridge setup? A carbon filter before the DI ones? That's kinda what I'm thinking about doing.
I bought a $120 dintank system and here I am looking at doing a like $400 setup for DI because someone needs to stop me, lol.
Pheonix408.50
      02-04-2025, 04:03 PM   #20
Pheonix
REP
1,020
See my post (#3) above.
Basically 5 microns sediment-5 microns Carbon- CR SPOTLESS DI resin Cartridge. The main reason, I am running only 1 DI Cartridge because I don't use a lot of DI water and the resin supposedly only lasted 1 year.
I might try to go down to 1 microns filters and also do the RV Mod for the DI Resin when i am ready for filters change.
      02-05-2025, 10:12 AM   #21
BlkGS
BlkGS's Avatar
4,101
REP
3,179
Drives: BMW X5 M50i
RV mod?
Out of curiosity, have you ever tested TDS after each filter to see how much they pick up? I'm thinking since I'm on city water a carbon filter to clean out the chlorine beforehand and save the DInresin some.
I didn't think the reason aged out? It just got used up by cleaning it up.
      02-07-2025, 10:58 AM   #22
Pheonix
REP
1,020
RV mod?
Yes, the modification by RV Mods repalce the cartridges with a Laser Cut Tube. Basically increase the DI Resin Volume and get more contact for better filtration.
https://rv-mods.com/store/DIC20-conv...kit-p105868881
No, I haven't check the TDS after each stage but from what I learned the Carbon will remove contaminants which help pro-long DI Resin (which it is expensive)
According to most sources, DI Resin should be replaced every 12 months. Not sure what would happen after 13 months but DI water tend to grow algae if stay stagnant. We have a large DI water system at work and have an automatic purge system to prevent issues with algae.
