02-08-2025, 12:57 PM | #1 |
![]() ![]() ![]() 21576
Rep 14,843
Garage List 2025 BMW M2 [9.67]
2022 G82 M4C X-Drive [9.78] 2018 F80 M3 CS [9.86] 2018 BMW i3 REx [4.87] 2015 BMW i3 REx [3.00] 2016 BMW F80 M3 [7.63] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [8.50] 2006 Audi S4 25Quattro [7.33] |
This is how to trick Bimmercode into coding Ambient Lighting in iDrive 8.5
EDIT: as of 2025/03/23 this method still works with the recent update to iDrive: 18.5 03/2025.30. Please make sure your bimmercode data update is current to v4.3(14092) 25.3.0. To check for data updates, open the app, select the gear icon on the lower right, then select "Check for Update".
EDIT: as of 2025/03/25 this method reportedly does not work with iDrive 18.5 03/2025.38. Thanks again to BIGW0RM for accidentally finding this exploit and being the first guinea pig! Currently Bimmercode v4.3(14092)-24.11.3, does not allow the ambient lighting to coded in the 2025 G87 M2 with iDrive 8.5. I was informed that this will be in a future Bimmercode update. However, for those who want to personalize the ambient lighting before the update, here is a step-by-step on how to achieve this. This will allow you to choose between 13 colors that will activate when selecting the “Ivory” setting in iDrive. The key is to tell Bimmercode to code for a "BMW 3 Series, M3" instead of a "BMW 2 Series Coupe, M2". I’ve coded this several times on my G87 M2 and I have not run into any issues. However, as with any coding on our bimmers, do so at your own risk. If you are not familiar with coding with Bimmercode, please follow my directions exactly. I'll try and make this as simple and through as possible. If something is unclear, please ask! Having said that, this is a very easy process and I’ll provide a step-by-step with screenshots. What you need:
You can get the hardware on Amazon: Here is just the Enet OBD2 Cable - https://amzn.to/3CJ0BT4 Here is a lightning to Enet Adapter - https://amzn.to/4hsuSEZ Here is a bundle for the Enet OBD2 Cable and USB-C adapter - https://amzn.to/3QaJaOm I HIGHLY recommend using an Enet cable instead of a bluetooth or wifi adapter. Some coding options through Bimmercode are ONLY available with an Enet OBD2 cable. It’s also 50 times as fast and much more reliable. With the wifi and bluetooth adapters, some loading screens can take almost 1-2 minutes, while using the Enet cable takes less than 1-10 seconds. Trust me, it’s just so much easier and more stable with the Enet cable. So now you have the 3 things you need. Here’s what to do:
That’s it! If you did everything right, you should have custom colors when you select “Ivory” in the iDrive. The new update supposedly will allow us to code more than just “Ivory” in the iDrive 8.5. Until then, we have this exploit.
![]() 2025 G87 ///M2 LCI - KWHAS, Millway Motorsport Uniball Camber Plates, SPL Adjustable Tie Rods, Unit17 OEM++ Rear Spoiler, Turner Motorsports Front Splitter Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3 Last edited by jmg; 03-25-2025 at 10:39 PM.. |
12
02-08-2025, 02:01 PM | #2 |
![]() 291
Rep 150
Drives: 2025 G87 M2
Thank you for this, very clear.
When you have some spare time, could you do similar for turning off ASD? ![]() |
02-08-2025, 04:07 PM | #3 | |
Rep 14,843
It’s pretty simple. Instead of selecting “Body Domain Controller”, select “Reciever Audio Module” and set “Active Sound Design” to “deactivated”. I’m not sure if it sticks, as it didn’t in some versions of iDrive 7.
![]() 2025 G87 ///M2 LCI - KWHAS, Millway Motorsport Uniball Camber Plates, SPL Adjustable Tie Rods, Unit17 OEM++ Rear Spoiler, Turner Motorsports Front Splitter Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3 |
02-09-2025, 01:01 PM | #6 |
You got my money?
![]() 4548
Rep 5,369
Drives: Ice Cream Truck
Hey, I just noticed something... My door cup holders appear to have LED in them. But no light is coming out of them. Im left wondering if this mod disabled them or of its just a hole for the LED which BMW does not have plugged in on the LCI.
Because the manual G87 M2 I had for three weeks. I had chris3g code the colors for me. And I dont see the cup holders lite up in the pics I took of my car after he was done. And I dont see the lite up with the color changes I made myself on my auto M2. So before anyone does this... do you door cup holder LEDs turn on? EDIT: Pics ive googled of a 25 M2 ambient lighting pictures and they dont show door cup holders luminated. WTF BMW.
2025 G82 M2 /// 2025 X5 40i X
02-09-2025, 01:28 PM | #8 |
You got my money?
![]() 4548
Rep 5,369
If you look in your door cup holder, at the top vertical part closest the outside of the doorcard you'll see a small indent. Thats where the lighting would come out of on a 23/24. Its like the size of a BB. Run you fingers around it and you'll feel the indent.
02-09-2025, 01:42 PM | #9 | |
Rep 14,843
I changed the color to Azure and it didn’t come on either.
02-09-2025, 01:44 PM | #10 | |
You got my money?
![]() 4548
Rep 5,369
Yeah I don’t think we have the leds in the door cup. Just the cut out. That or they are disabled by BMW.
02-09-2025, 01:44 PM | #11 |
Rep 14,843
Another cost cutting?!
02-09-2025, 01:45 PM | #12 |
You got my money?
![]() 4548
Rep 5,369
I guess so. The 23 guys have them in the door cup and door storage from what I can tell.
02-09-2025, 01:54 PM | #13 |
this is the way
21054
Rep 9,164
02-09-2025, 01:57 PM | #14 |
Rep 14,843
Can anyone else with a 2025 that hasn’t coded yet triple confirm that their cut holder light doesn’t turn on?
02-09-2025, 08:46 PM | #15 | |
![]() 2816
Rep 2,747
I also successfully coded Ma lights (red.) NICE. I had to turn the brightness down. It was super intense. Kinda looked like I was in the pit of hell or something.
///M
02-09-2025, 09:23 PM | #16 | |
Rep 14,843
Thanks for confirming!
02-10-2025, 08:35 AM | #17 |
You got my money?
![]() 4548
Rep 5,369
I wonder if we can add those leds back in the door cup holder. Here’s a 22/23 that have them in the cup holder and storage cubby.
https://g87.bimmerpost.com/forums/at...1&d=1637804534
02-10-2025, 02:11 PM | #18 | |
Rep 14,843
02-10-2025, 04:32 PM | #20 |
You got my money?
![]() 4548
Rep 5,369
I actually checked there site thinking the same thing. Us LCI guys got the shaft on ambient lighting. The door cup and umbrella holder cubby storage LEDs would be a nice improvment for us.
///MoT307.00 |
02-11-2025, 10:00 AM | #21 | |
Rep 14,843
https://www.bimmerpost.com/forums/sh...php?p=31845849
BIGW0RM4547.50 |
02-11-2025, 03:49 PM | #22 | |
You got my money?
![]() 4548
Rep 5,369
Here is the parts list. He did say that he got it all working. BUT, if he choose two different colors. Top to bottom. That one side would be top color and the other side the bottom color. But if he choose all the same color, no problem. https://g80.bimmerpost.com/forums/sh...ostcount=12285
jmg21575.50 |
