BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      02-09-2025, 01:19 PM   #1
OneTwo3
Drives: Toyota Camry
Help me with this fitment math.
Stock g87 wheel sizes are
Front 9.5 x 19” ET20mm
Rear 10.5 x 20” ET20mm
a staggered Edelweiss LT3 set is
Front 10.5 x 19" ET14mm
Rear 11 x 20" ET12mm
Compared to stock, the edelweiss fitment would be the equivalent of having around an 18mm spacer in front and 15mm in rear for the stock wheels.
Is this correct?
      02-09-2025, 02:09 PM   #2
aerobod
Car Geek
aerobod's Avatar
Is this correct?
No, ET is based on wheel centerline, not wheel width. It is the equivalent of 6mm front and 8mm rear spacers.
From a tyre clearance perspective, assuming some increase in tyre width to match the wheel width increase, the sidewall will be about 8mm closer to the strut and 19mm closer to the fender at the front, at the rear about 2mm further from the inner wheel well and 14mm closer to the fender. If you use the same tyres they will look more stretched and will not be as close to the strut or fender than the appropriately wider tyres.
      02-09-2025, 07:22 PM   #3
OneTwo3
Hmmm, this seems off.
The front wheel’s offset difference is 6mm(negative direction), meaning the new wheel sits 6mm further out compared to stock based on offset alone. Since it’s also 1 inch (about 25mm) wider overall, that adds roughly 12mm to each side.
So in total, the wheel should sit about 18mm further out.
Does that sound right, or am I misunderstanding how offset works?
      02-09-2025, 08:06 PM   #4
aerobod
Car Geek
aerobod's Avatar
That is correct if the tyre size increases by the width of the wheel, but the tyre sidewall should be the widest part of the wheel/tyre assembly unless a ridiculous stretch beyond tyre spec is done. If you use the stock tyres on a wider rim, the sidewall won't move out as much as the rim width increase as the tread is still the same width, the tyre will just become more stretched
Putting 295 or 305 wide tyres on all 4 wheels wider wheels would bring the tyres out to a point close to where the stock wheels and tyres with 18/15mm spacers would be. The 285/30-20 rear tyres are only recommended on rims up to 10.5" wide anyway.
      02-09-2025, 08:09 PM   #5
OneTwo3
I see. I want taking the tire into account at all. Thanks!
aerobod4431.00
      02-10-2025, 08:49 AM   #6
Vojta89
Vojta89's Avatar
Czech_Republic
161
Drives: 2025 G87 M2 (expected 4/2025)
Is this correct?
Next time you can just use willtheyfit.com
2009-2011 E90 320si street/track car - SOLD ; 2010-2016 E92 330d LCI street car - SOLD ; 2016-2018 F30 335d LCI street car - SOLD ; 2011-2021 E46 M3 track car - SOLD
2018-2024 F87 M2 Competition street/track car - SOLD ; 2021-???? 1986 E28 M535i show car ; 2025-???? G87 M2 street/track car
My Instagram
      02-10-2025, 08:53 AM   #7
OneTwo3
Nice! Thanks for sharing. It looks my math was pretty close.
      02-10-2025, 12:20 PM   #8
aerobod
Car Geek
aerobod's Avatar
Although that site shows rim position, it doesn't show the tyre clearance, which is generally the issue for rubbing and getting a flush looking fit.
A 275/35-19 MPS4S has a nominal width of 275mm, but the quoted measured value on a 9.5" wide rim is 277mm with a 249mm tread width. On a 10.5" rim it isn't going to have a measured width that increases by 25mm, it is going to be more like about 290mm and the tread width is still 249mm. The tread position is only going to move by the ET change in the wheel - 6mm in this case.
A 295/30-19 MPS4S has a nominal width of 295mm, with a quoted measured value of 302mm on a 10.5" wide rim and a 279mm wide tread. It's sidewall will move out equivalent to a 23mm spacer on the stock wheel and tread will move out equivalent to a 21mm spacer on the stock wheel, but the position of the tread edge will be 8mm closer to the wheel centre. The 285/35-19 MPS4S has a tread width of 254mm, so it will be equivalent to using an 11mm spacer on the stock wheel when looking at the edge of the tread, which will also be 4mm further away from the wheel centre.
