02-11-2025, 07:36 PM | #1 |
![]() 86854
Rep 1,071
Expensive watches~ Cheap quartz movements.
One thing I've noticed since I started replacing batteries in my watches, is how inexpensive the movements are.
From my sub $100 beaters to my more luxurious pieces, the movements are practically the same. Unlike mechanical watches intricate hand assembly, these engines are essentially machine made and just dropped into a case by an assembly worker. I deal with a watch retailer located in Vancouver and here's a list of movements they provide and look at the prices in CAD : https://perrinwatchparts.com/collect...atch-movements When you spend thousands for a time piece, you kind of wonder where the money is actually going... |
02-11-2025, 07:49 PM | #2 |
![]() ![]() ![]() 11664
Rep 7,223
Drives: 2018 M2 AW DCT
That is why I buy manual movements. 🤓
BMWCCA member Puget Sound Chapter
02-11-2025, 07:58 PM | #3 |
![]() ![]() 9965
Rep 4,145
^ This. I have quartz watches but they are inexpensive beater watches. Nothing wrong with them but I’m not paying up for quartz movement.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 ![]() |
Lady Jane86854.00 |
02-11-2025, 08:10 PM | #4 |
![]() 86854
Rep 1,071
02-12-2025, 01:04 AM | #5 | |
#buildnotbought
14669
Rep 5,610
Movements like that (say like a GS 9F series, found in GS watches in the 2k-4k range) usually can only be bought through the official channels, not generic wholesalers. But indeed, there are a whole bunch of cheap quartz movements that are more of the throwaway type. Only battery replacement is done, everything else is replace. But there are also a whole lot of OEM seiko, myota and maybe sellita movements (and a lot of chinese ones) that also hardly justify a service. A seiko 6R movement can already be had at around ~€200, and that isn't even the bottom tier movement line (7s26 for instance can be found for €80) So movements like these also already are of the throwaway type. That said, paying thousands for a quartz watch...watches are almost never a sensible investment, but those certainly arent, unless you have a very special limited model maybe. (I'm talking new here, vintage is another world....)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
ebirotedu1687.50 |
02-12-2025, 04:33 AM | #6 |
![]() 168
Rep 149
When one spends many Townsends of Dollars on a watch with a Quartz movement, you are usually paying for the brand name or the precious metal casing/diamonds etc. One exception may be the FP Journe Elegante, which is made by the best watchmaker alive, and which price is outside of most people's reach.
While Quartz gives you more time accuracy than mechanical movements, with proper service, that latter mechanism can last you a hundred years or more. Battery operated quartz ones, have not been around for that long, so the jury is still out on their centenarian longevity. But at the end of the day, every individual spends their hard-earned money as they see fit. Last edited by soldes; 02-12-2025 at 10:16 PM.. |
ebirotedu1687.50 |
