      02-12-2025, 11:23 AM   #1
Digitalprty
Digitalprty's Avatar
Drives: 2024 M2
Regrets
What, if anything, have you done to your M2 that you wish you hadn’t?
      02-12-2025, 11:47 AM   #2
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
The last RWD, manual, luxury, DTM, muscle car, that BMW will likely make? The only regret would be not buying one sooner but I got the first custom ordered carbon car off the assembly line so...no no regrets. Go drive the thing and enjoy every second of it.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
RMB278.50
mrdudley626.50
      02-12-2025, 12:31 PM   #3
JABCAT
Professor
JABCAT's Avatar
4971
Tbh - I've been modding cars for so long, I typically do a lot of research before making any changes/additions. That being said, I'm not 100% satisfied with the mid-pipe & exhaust set up I have. I don't know if it's the mid or axle-back that I'm unhappy with, but that a fairly expensive change.
      02-12-2025, 01:48 PM   #4
F87inJAX
F87inJAX's Avatar
Drives: F87 M2
Which mid did you go with?
      02-12-2025, 05:38 PM   #5
JABCAT
Professor
JABCAT's Avatar
4971
The Dinan unresonated x-pipe. I get drone at 2800-2200 rpm which is exactly where my car stays at 80-85 mph on my 4 hour drive 2x every week. I'm not sure if it's the x-pipe or the exhaust. The other mids are pretty much 2x the price which I feel is excessive for such a short piece of pipe.
mks158.50
      02-12-2025, 06:52 PM   #6
jmg
jmg's Avatar
20357
I didn't option the Carbon Buckets. In my G82, I had a good reason: ventilated seats. The G87 doesn't have this option, but I felt like the buckets would be too uncomfortable for my... *ahem* girth.
However, I think I could have delt with it. I got this M2 to hold myself over for the M2 CS, and to "test drive" it for an extended time, with the possible intent to trade it for the CS, depending on the price. I have no data to prove it, but now I'm wondering if the Carbon Buckets would retain more value. Other than that, they are just super cool and supportive. I think whatever I get next, I'll be optioning the Carbon Buckets.
2025 G87 ///M2 LCI - KWHAS, Millway Motorsport Uniball Camber Plates, SPL Adjustable Tie Rods, Unit17 OEM++ Spoiler
Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3
      02-12-2025, 06:57 PM   #7
xtougher
Drives: 2024 G87 M2 6MT
I didn't unclick the phone warmer before finalizing the order.
mrdudley626.50
jmg20357.00
pchoi8826.50
      02-12-2025, 07:10 PM   #8
mrdudley
mrdudley's Avatar
Drives: BMW X3 M40i
Cars with carbon buckets will definitely sell for more, but like most options, probably not enough to justify the initial cost if your only goal was holding value. Especially if you bought a 23 or 24 and had to get the whole carbon package. The primary reason to buy them is if you like them (functionally or even cool factor).
jmg20357.00
M2M3M3321.00
      02-12-2025, 07:34 PM   #9
rk95
rk95's Avatar
Drives: BMW M4
[QUOTE=jmg;31858743]I didn't option the Carbon Buckets. In my G82, I had a good reason: ventilated seats. The G87 doesn't have this option, but I felt like the buckets would be too uncomfortable for my... *ahem* girth.
Can attest by recently selling my vehicle that dealers truly don’t care about the buckets unfortunately.
jmg20357.00
      02-13-2025, 02:07 AM   #10
LateBrake8
Drives: E46 M3|F36 435i|C7 RS7
They certainly do when they're on the selling side.
      02-13-2025, 02:57 AM   #11
jmg
jmg's Avatar
20357
Did you negotiate by chance?
      02-13-2025, 06:43 AM   #12
rk95
rk95's Avatar
Drives: BMW M4
You’re absolutely right about this. I did negotiate but they still turned around and listed it for an insane amount after I sold it because of the seats.
      02-13-2025, 08:47 AM   #13
mks
equo non credere equitem
mks's Avatar
Drives: 2024 M2
Agree re: cost. I've been looking for less expensive, carb legal options and thought the Dinan X-pipe (D660-0101) would be my solution. I have anecdotal testimony from at least 2 who claim there's no drone with just the x-pipe. However, I've yet to find any vid or in-person proof that address drone specifically. Curious, in your research, did you find anyone who installed just the x-pipe?
Like you, I tend to do a lot of research. I've also done decades worth of modding. Not to break the myths associated w/res-deletes (I'm sure some are true in certain platforms), but very rarely have I had to do full exhausts because I've found that they (res-deletes) produced the result for which I was looking. Some might be surprised to learn that most of my Mustangs (including my Dark Horse) had simple, cheap res-delete pipes on them. Aggressive notes with zero drone (important to me as we do a lot of long road trips). However, I'm not as familiar with the G87 design...so, don't know if the resonators are really affecting drone the way we might assume.
Dinan's vid
For what this highlights, the vid is good enough. But not the comprehensive demonstration for which I'm looking.
ACI Dynamix (the closest I've found to anything that covers drone)
*Rasp is another concern. While some say it's unavoidable, I don't detect any rasp in this vid.
      02-13-2025, 09:21 AM   #14
AZG87
Drives: G87, 2018 Mustang GT traded in
Drone is typically associated to the muffler solution more so than a mid. What exhaust / axle back are you running? For example a straight through track design will tend to drone more.
mks158.50
      02-13-2025, 04:27 PM   #15
JABCAT
Professor
JABCAT's Avatar
4971
I have the MAD axle-back with the Dinan x-pipe. Like above there were a couple people with this set up that said absolutely no drone, but there definitely is in my car. I thought maybe the mid-pipe was touching the heat shielding in the tunnel as it was very close. Created more space, so that wasn't it. At 2k rpms my car buzzes & vibrates. Below 1800 or above 22-2300 rpm, no buzzing or vibrating. I do have the valve fuse pulled with them in the factory open position. This is much better than with them closed re: the drone.
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo full Merino interior.
His: '23 M2, Toronto Red Metallic, M highlight interior.
'11 Callaway SC652 Carbon Edition Corvette Z06. Inferno Orange Metallic. 1 of 3.
dexter149.50
mks158.50
