BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      02-12-2025, 10:18 PM   #1
Scrutineer
Scrutineer's Avatar
189
Drives: 2025 M2 - Brooklyn Grey
Spacers with OEM Wheels/Yokos/Suspension
My head spins when I try to parse the winning solution from the threads I’ve seen. Too many variables! For example, I’ve gathered that 15mm in front works with other OEM rubber, but not with Yokos.
Please keep it simple and post what size spacers worked for you only if you:
a) are not lowered;
b) are on OEM wheels (930s); and
c) are on OEM Yokohama Advan Sport V107 tires.
Thanks in advance!
      02-12-2025, 11:58 PM   #2
mikeysix
mikeysix's Avatar
28
Drives: G87 M2 LCI
Would be keen to hear some feedback on this. I am in exactly the same position. I have 15mm spacers waiting to install once the run in service is complete. So would be good to know if I will need to modify the liners.
      02-13-2025, 10:33 PM   #3
SpaceGhost
Drives: 2025 M2, 2024 740i xdrive
I believe the issue with rubbing on yokos and 15mm spacers is only when lowered.
      02-13-2025, 10:42 PM   #4
///MoT
///MoT's Avatar
229
Drives: 2025 G87 M2 SGM
2025 BMW M2  [10.00]
I have 15mm spacers for front and rear, and meet the criteria for a, b, and c. I just haven't installed them yet.
Scrutineer can you please point us to a thread regarding "15mm in front works with other OEM rubber, but not with Yokos."
Also, check out this video at 2:54, where they state BMW "fixed" the rubbing issue with the M2, compared to the M3 and M4 that still having rubbing issues even with 12mm spacers:
///M
      02-13-2025, 11:04 PM   #5
Scrutineer
Scrutineer's Avatar
189
Go ahead and mount them up and let us know how it goes, my good man!
https://www.bimmerpost.com/forums/sh...php?p=31544520
There’s further discussion elsewhere in that thread, but this is the post that has me starting threads like this one.
///MoT229.00
      02-13-2025, 11:33 PM   #6
///MoT
///MoT's Avatar
229
2025 BMW M2  [10.00]
Thanks for the link to the other thread. I wonder if there's any difference between the '23/'24 and the LCI '25 when it comes to the rubbing issue with Yokos?
I'm still healing up from retina detachment surgery, so will be a while before I get my spacers on to try things out. But once I do, will report back my findings.
-Tom
///M
      02-14-2025, 11:56 AM   #7
Scrutineer
Scrutineer's Avatar
189
-Tom
Sorry to hear you’re dealing with that and I hope the recovery is smooth.
///MoT229.00
      02-14-2025, 03:20 PM   #8
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
-Tom
I had two retina detachment surgeries and over 20 laser procedures to reinforce the bond from those surgeries when I was 25.
It was a challenging time that required a lot of patience. Wishing you all the best in your recovery.
https://x-ph.com/sale/
Phone number 702-494-9435
///MoT229.00
      02-14-2025, 07:39 PM   #9
mr. zero
Drives: 2025 VEGAS M2 6M
2018 BMW M3  [10.00]
Just checked, I have the Yokos, and I did 15 all around. Had to do the liner modification, as it would rub while reversing at full lock. That being said, do not experience any rubbing now.
///MoT229.00
      02-14-2025, 08:02 PM   #10
Scrutineer
Scrutineer's Avatar
189
Thank you very much for that report! Two follow-ups:
1. Only the front is an issue with 15mm, right? Rears are fine?
2. What’s your best guess - would 12mm in the front be fine?
Dokker0.00
      02-15-2025, 09:06 PM   #11
Dave07997S
Dave07997S's Avatar
1484
Drives: 2024 BMW M2 Toronto Red 6MT
People had rubbing even with 12mm on the front, its hit or miss. No issues with the rears...I run 15mm with Yokos and only had rubbing in the front not the rear. I know several people who were running the Mich PS4s and they had rubbing with 12mm on the front.
(Sold) 2020 Ford Mustang GT 6MT PP1 444rwhp
2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk, 2001 BMW M3
      02-15-2025, 09:54 PM   #12
SpaceGhost
Dave, I may have asked this before (can't remember) but can you post a pic of your fins so we can see which fins you cut and how much?
I am on yokos and plan to have my spacers installed on the 25th. Need to know if i need file or snip the fins.
      02-15-2025, 10:38 PM   #13
Mikesbimmer
Drives: M2
I’m max low on MPHAS with Yokos and 12mm spacers. I’ve only barely rubbed twice at full lock in reverse. I pushed hard on the fender liners and I think gained the 1 mm or so to prevent further rubbing. No big deal.
      02-16-2025, 09:58 AM   #14
gondolafanclub
Drives: 2025 M2
i have stock suspension, yokos, 15mm front, 12mm rear
the rubbing very rarely happens and it doesnt seem like its damaging anything so i'm not gonna worry about it
///MoT229.00
      02-16-2025, 11:18 AM   #15
///MoT
///MoT's Avatar
229
2025 BMW M2  [10.00]
When it does happen, is it in reverse with wheel at full lock?
///M
      02-16-2025, 12:20 PM   #16
gondolafanclub
Drives: 2025 M2
thats all ive noticed yeah, I have to do that every time to get into my garage and i only hear it rubbing like 1 out of every 4 or 5 times I back up
///MoT229.00
      02-16-2025, 12:46 PM   #17
WWM3
WWM3's Avatar
Drives: 2018 GT3, F80 CS
I have the Yokos and have ordered Eibach springs and 12mm spacers front and rear. I’m hoping I don’t have to modify the inside front bumper.
Past: 1999 M3 2003 M5 2006 330i 2007 335i 2009 M3 2013 M3 2018 M3
      02-16-2025, 01:52 PM   #18
Scrutineer
Scrutineer's Avatar
189
Thanks for the info. I think this locks me in on 10mm/15mm. Seems like the safest play. I have no appetite for adjusting or replacing the liners. That’ll be better than nothing up front.
///MoT229.00
      02-16-2025, 09:57 PM   #19
Dave07997S
Dave07997S's Avatar
1484
Its pretty rough, I need to take the wheel off and clean it up. Sorry I haven't been on the board much (had the flu). I will take a pic. I took some chalk (climbing chalk) and put it on the fins. Thats how I figured out which fins were rubbing. It still rubs a tad depending on the way the springs are loaded up due to undulations in the driveway.
      Yesterday, 03:35 PM   #20
D4VE
England
170
Im on mphas kit and asked my local dealer to give me a price on some 1000m wheels there reply would suggest theres some small trims for the arches and I'm guessing these are to prevent rubbing, below is the reply, it might be worth speaking with your dealer.
"Good afternoon.
I have put together a quote for the Wheel & tyre set.
There are some additional items that will need to be supplied with the wheels which are small trims for the arches"
