      02-15-2025, 11:00 AM   #1
Westside Guy
Westside Guy's Avatar
7621
Drives: 22 Z4 M40i, 21 228i Retired
What spray do you use on your ceramic coating?
What product/ spray do you use to clean and maintain your ceramic coating?
      02-15-2025, 11:16 AM   #2
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
I've been happy with the Adam's "Graphene Detail Spray". But I have a newish coating on the Z4 (DIY) so it is probably hard to tell which one is doing the job. It goes on and off easily and is a low enough % that you don't need to be too worried about leaving something behind that you didn't polish / buff / whatever you call it. I do still spray it on the towel down wind just in case.
I also started putting it on my X3 that has a bunch of Zaino on it, and can tell it beads water / snow is easier to remove longer than the Zaino itself ever did. I know you're not supposed to put one type over the other but for that car I don't care a ton and it has actually been working. I tried it as a test and am glad I did.
Typically I just use the normal car wash soaps but have a "strip wash" that you supposedly use once a year, but I haven't had the Z4 a full year yet so I'll give that a go this spring.
      02-15-2025, 12:15 PM   #3
BroDoze
Drives: 2025 M2 LCI
Dr. Beasley’s.
Always and only Dr. Beasley’s. The best.
///M
      02-15-2025, 12:27 PM   #4
Westside Guy
7621
Originally Posted by BroDoze View Post
Dr. Beasley’s.
Don’t they sell more than one product?
      02-15-2025, 12:59 PM   #5
afadeev
afadeev's Avatar
1299
Drives: F80 M3
Clean vs. maintain are two separate questions / answers.
Clean - if the entire care is dirty - wash it. If only a section needs to be clean, I use waterless wash on a microfiber towel to wipe-off the dirt or bird poop.
Maintain - all brands have some sort of spray-and-wipe ceramic "booster" product, or "detail" spray. I used to stick within the brand family of the base ceramic coating product I had used on that car. So, since I started with Adam's on two cars, I also got Graphene CS3 (which is what Adam's rep recommended for maintenance).
For my McKeys and Gyeon coated cars - I either use the above, or another similar McKeys branded spray product I had bought (one or the other brand goes on sale ever so often). Frankly, they all seam to work the same, and are highly interchangeable.
I don't regularly "boost" any of the coatings, nor does the coating look or bead water any different in areas where spray was recently applied. To a large extent, "boosters" are a way to add recurring revenue after selling you the ceramic coating.
IMHO,
a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White)
'25 Lexus RZ (White/Blue)
ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's
      02-15-2025, 02:29 PM   #6
cbpip
cbpip's Avatar
270
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
You can make your own Elixir. Carpro and most detailers are mostly water in their bottled products. So making your own cost considerably less.
Carpro Merlins Mixture there are a lot of results, people commenting on multiple combinations.
2oz Reload / 2oz Ech20 / 28oz Distilled Water.
spazzz167.00
      02-16-2025, 04:41 PM   #7
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
Shouldn't use any spray on top of ceramic coating except to extend its life near the end, before you polish and coat again.
Use an iron x product periodically. Use good soap with no b.s. in it.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      02-16-2025, 11:28 PM   #8
BroDoze
Drives: 2025 M2 LCI
Nope. Just towels. But they're the best.
///M
