02-16-2025, 05:52 PM | #1 |
Rep 6
Wheel Spacers
Hey all,
Looking to lower my 25’ M240i on some Eibach springs. Curious if anyone has any recommendations on spacer sizes? Looking online I’m seeing a lot of 12mm front w/ 15mm rear. Based on some pics I’ve seen, the 15 in the rear looks like it pokes out a bit- is it just the angle of the photo? I’m not looking to have any poke in the rear. I was thinking about playing it conservative and going 12mm all around, but if the 12/15 setup gives it that aggressiveness without poking out, I’ll for sure go that route! I have the ZTK package so curious what works best with the added fender flares. Thanks for any recommendations! |
02-17-2025, 10:40 AM | #3 | |
![]() 2287
Rep 2,728
For the above: 12mm front, 10 or 12mm on the rear. (I have 10 as I felt 12 was slightly too much). I’d lower the car and buy one pair of 12mm spacers and then check the effect on front and rear axles. Then you can go up/ down or stay the same size on the remaining axle. |
BT226.00 todd hollander131.00 |
