BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      02-25-2025, 04:53 PM   #1
elprincep
REP
56
Drives: BMW m240i
Brake fluids
Which brake fluid do you recommend for daily driving and sporadic trackdays ?
      03-04-2025, 03:36 PM   #2
Saigonheat84
REP
72
Drives: 2014 bmw 328i, 2024 bmw m2 g87
Motul 600 for daily and occasional canyon run.
Motul 660 for track day.
Im currently using the Motul 600
      03-04-2025, 10:56 PM   #3
HP Autosport
Supreme Allied Commander
REP
56,341
Drives: F80 M3
Castrol SRF. It is one of the best in the industry, with one of the highest wet boiling temperatures.
X_Drive103.50
      03-05-2025, 12:23 AM   #4
X_Drive
X_Drive's Avatar
Japan
104
REP
319
Drives: E46, E91, F20, F87, G87
2025 M2  [10.00]
2010 328i xDrive  [10.00]
I used RBF660 in my F87 Comp. Never let me down. Using it in the G87 now as well. However, SRF (pricey) and Torque(when you can find it) are probably the best in the biz due to fantastic wet boiling points.
I'll probably switch to either one when my case is done.
      03-05-2025, 11:50 AM   #5
HP Autosport
REP
56,341
Drives: F80 M3
If you are too lazy to flush after each event, the SRF will still have a very high wet boiling temperature, whereas the others don't.
      03-05-2025, 02:12 PM   #6
LeggoRacing
LeggoRacing's Avatar
421
REP
210
Drives: M2
Endless has been my favorite in multiple cars. Good compressibility characteristics and helps pedal feel
X_Drive103.50
lutfy317.50
      03-05-2025, 06:03 PM   #7
Speedy
Speedy's Avatar
Spain
20
REP
16
Drives: BMW M2 f87 LCI
I’ve been using the RBF 600 for many years until I discovered the Ferodo Super Formula, which to me is much better at everything.
Both are DOT 4, so you avoid the problems of the DOT 5, but in my experience the Ferodo has better resistance to high temperatures and degrades better over time.
X_Drive103.50
      03-05-2025, 07:56 PM   #8
chris719
REP
7,558
Drives: '08 M Roadster
G87 and all new BMWs are designed for low viscosity brake fluid. The ABS pump won't work as fast with thicker DOT 4 fluids. You should use DOT 4 LV / DOT 5.1 or Bosch ESI6 for street use.
Speedy19.50
aerobod4502.50
      03-06-2025, 08:57 AM   #9
Speedy
Speedy's Avatar
Spain
20
REP
16
Well, thank you, that's good to know! My current car is an M2 F87, and in the summer, I will have my new G87. However, I am not aware of the recommended viscosity of brake fluid for the new GX models.
Your answer would have prevented me from using the Ferodo DOT 4 for the new M2!!
      03-06-2025, 12:05 PM   #10
aerobod
Car Geek
aerobod's Avatar
REP
4,093
In high ambient temperatures you may not notice the difference between a normal DOT4 and DOT4 LV fluid, but in lower temperatures we see here in Canada it certainly makes a difference in the winter with really slow and inconsistent operation of the ABS & DSC with non-LV fluid when it is very cold.
BMW have actually specified LV fluid for more than a decade now, as have Porsche. Best to swap between LV fluid for winter use and non-LV fluid only if needed for track use. With a manual car, non-LV fluid will also cause more intrusive CDV (Clutch Delay Valve) delays in the clutch pedal return, if the valve hasn't been removed.
Speedy19.50
chris7197657.00
      03-06-2025, 02:56 PM   #11
chris719
REP
7,558
It's actually a requirement as far back as E9x I believe. I'm not sure it's really a big problem or anything, but for street use I think Bosch ESI6 is probably the best stuff available.
      03-06-2025, 07:32 PM   #12
ggggbmw
REP
505
Drives: 2017 M2 Manual
This is what I do. Every spring I put in Castrol SRF for track days. And every fall I put in Pentosin LV or ATE SL.6 (also LV) for the winter.
If you aren't tracking, you are probably better off just changing the LV fluid every year. Unless you are really torching the brakes on a track, fresh fluid has nearly the same 'dry' temp limits as track fluids, and will work just as well. And if you flush every year, it will never get 'wet'.
aerobod4502.50
chris7197657.00
      03-08-2025, 06:10 AM   #13
Speedy
Speedy's Avatar
Spain
20
REP
16
Okay, I had no idea. Probably because where I live, the temperatures in winter almost never drop below 10ºC (50ºF) ... in very exceptional situations, we can get down to -1 or -2ºC (30ºF or 28ºF), but very punctual days and very occasionally.
The problem is usually more of summer temperatures, which reach 30ºC (86ºF) or 35ºC (95ºF) and overheating of the brakes in track.
However, in central Spain, it is easy for temperatures to drop below 0ºC (32ºF) in winter, and yet I had never read any problems with low temperatures with brake fluid. Very interesting, in any case! Thanks for the information!
chris7197657.00
