E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Sunroof Problem!!!
Reply
      06-06-2006, 11:42 PM   #1
Collanrf
Collanrf's Avatar
Philippines
86
Drives: BMW 335i, Alpine White M Sport
2011 BMW 335i  [0.00]
Angry Sunroof Problem!!!
When i started my car, the indicator light came on for the Sunroof. I tried to put it in Vent position but it won't work. Tried to close it but it opened half way WTF!!! I did it again when i got home but but no luck at all :mad: Any of you guys have this problem?
/// 2011 E90 335i M SPORT, ALPINE WHITE/// STEPTRONIC /// ZENON HEADLIGHTS/// 35% TINTS ALL AROUND /// 19 INCH BBS LM REPS ///BLACKED OUT ROUNDELS /// BLACK OUT GRILLS/// ACS ROOF SPOILER /// M3 REAR SPOILER /// LTMW INSTALLED (VOLLKOMMEN) M SPORT FRONT LIP /// BMS INTAKE///
      06-06-2006, 11:45 PM   #2
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
Leave the car off for say 1 hour then try to vent it. If you can, then hold the switch in the vent position for at least 10 seconds to reset the sunroof. If that fails, take the car to the dealer.
I hope all goes well with the sunroof.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      06-06-2006, 11:47 PM   #3
Collanrf
Collanrf's Avatar
Philippines
86
Thanks alot. I hope it works.:rocks:
      06-06-2006, 11:55 PM   #4
David328M-Sport
Australia
101
Me too. Good luck
      06-07-2006, 02:22 AM   #5
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
ALL you need to do is initialize your sunroof.
What you do is you get into your car, put your fob in the slot and turn the car ON (ie don't start it - but push the start button with your foot OFF the break/clutch)
Now, push and HOLD the sunroof button up (vent position). After about 15-20 seconds, the sunroof will vent. CONTINUE HOLDING THE BUTTON UP. After anouther couple of seconds, 15 or so (could feel long, but keep holding) , the sunroof will close, the open completely, then close completely.
Once the sunroof has closed completely, the proccess is over. It's important that you do not let go of that button while the proccess is happening.
Warnings might come up on i-drive or the on-board-computer. That is normal during this initialization.
SlimE92185.50
Thorin117.50
      06-07-2006, 05:52 AM   #6
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
There is always manually closing the sunroof by removing the cover and using the wrench to manually close it. Check your owners manual for directions. Might rain. Hope not and good luck!
Can you say Alooooha?
[SIGPIC][/SIGPIC]
      06-10-2006, 09:18 AM   #7
Collanrf
Collanrf's Avatar
Philippines
86
Sunroof fixed already, They just reloaded the software.
      06-10-2006, 05:03 PM   #8
brian32e
brian32e's Avatar
16
Drives: '06 Alpine White 330i ZSP
Good to hear. What was your build date and which dealer did you get it fixed at? Same one that you bought from?
      06-11-2006, 12:06 AM   #9
Collanrf
Collanrf's Avatar
Philippines
86
Aug and the dealer was BMW of San Diego. I already had my software update last dec. but there was an error on the software so they updated it again.
      07-11-2007, 10:53 AM   #10
oneshare325
oneshare325's Avatar
Drives: E90 325i, E82 135i
2018 BMW M3  [0.00]
2006 325i  [0.00]
Old thread
I just got this problem yesterday, and I will try and fix it when I get home!! Thanks for the info! (good example that everything has already be posted, and a search will find it!) Thanks again!!
      07-12-2009, 10:39 PM   #11
lsdless
lsdless's Avatar
Drives: E92 335i 6MT
Just what I was looking for! I didn't want to go back to the dealer again. thanks to this info I don't.
      08-06-2009, 08:49 PM   #12
yonex8000
Drives: 325i
I did initialize the sunroof. It work fine. Thanks
      08-06-2009, 08:55 PM   #13
Dr.G
Dr.G's Avatar
Drives: Not enough room!!!
this forum rocks!!!
      10-26-2009, 10:07 AM   #14
GUNN IT
GUNN IT's Avatar
Drives: 2006 325i Sedan E90
I've got the same problem... I just don't have time to go to the dealer so I was hoping to find some reset technique here, I am going to try doing what "Broken 1" recommended, hopefully that'll work.
Will update if it does.
      10-26-2009, 12:30 PM   #15
chaz58
chaz58's Avatar
15
Drives: 328iT
What Broken recommended is listed in the service manual for the e90, its the first thing I do if the sunroof gets out of alignment or otherwise gets flakey
_________________________________________________
      10-27-2009, 08:07 AM   #16
GUNN IT
GUNN IT's Avatar
I tried what "Broken 1" recommended, it worked like a charm.
THANKS
      10-27-2009, 11:41 AM   #17
TommyK
TommyK's Avatar
Drives: E90 335i LCI
2009 BMW 335i LCI  [0.00]
2006 E90 330i  [0.00]
how does the sun roof break like this, mine does it 3 times a year and i rarely use my sun roof. i know how to fix it since i asked my SA so i wouldnt have to come in everysinge time
      02-26-2011, 03:32 PM   #18
330iLiiike
Drives: 2006 330i
I appear to be having the same problem...
I tried the reset/initialize reccomendation and am not having any luck...
my runroof is in the slide mode about 1/4 open and stuck!
i put my key in ignition, foot off break and clutch, pushed start button and held the sunroof button upward in tilt postion for at least 30 seconds and nothing happens. Am i posible doing something wrong?
Assistance is graetly appreciated
thanks
2006330iliiike
      05-08-2011, 06:37 PM   #19
slimmie
Drives: 2008 JB e92 335i
Just did this now cuz sunroof was acting up..
Worked like a charm... thanks!!
      05-18-2011, 02:11 PM   #20
NaNo_F1
NaNo_F1's Avatar
Drives: 07 E90 328i
I will give this a try today! Same deal as everyone except mine is closed, hopefully it will work!
      05-18-2011, 02:37 PM   #21
MCOChuck
MCOChuck's Avatar
Drives: 2012 E92 328i xDrive M-Sport
we have a sunroof trouble light in our cars?
      05-19-2011, 10:26 AM   #22
NaNo_F1
NaNo_F1's Avatar
Drives: 07 E90 328i
Worked like a charm!
Reply
e90post
