How will the dealer fix this?
06-07-2006, 07:41 PM | #1 |
Rep 147
My front right tire has been leaking air for a few weeks now. At first I thought i needed an alignment, but after filling the tires to their recommended levels a few times and then noticing a loss in pressure in that one tire I was able to eliminate that as the problem. After filling it to 29 psi last weekend its already at 23, the other tire is still at 29psi.
I'm bringing the car to the dealer friday? Has anyone else had a problem like this with their runflats? And will the dealer replace the tire, or reseal it?!? The tires have less than 5000 miles. And I checked for nails/screws, so thats not it. |
06-07-2006, 07:58 PM | #2 |
Rep 6,158
there's a leak
they'll find the leak and charge you to fix it, leaks aren't usually waranty work often times a nail can be hard to see, but it's almost certain you've got some sort of puncture |
06-07-2006, 11:19 PM | #5 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Just thinking the same thing that they might not be screwed in tight and letting some air out. The warning light should've already come on by now.
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
06-07-2006, 11:23 PM | #6 | |
Rep 147
06-07-2006, 11:25 PM | #7 |
Rep 9,788
I've had that once. They replaced a run-flat for me but didnt put the tire on right. A little piece of rubber was pinched between the wheel and tire so air kept leaking out. Maybe you're experiencing the same thing...
06-07-2006, 11:48 PM | #8 |
Rep 6,158
if it's just recently starting it's got to be a puncture
no way it's not a puncture or you'd have had this problem the whole time you've owned the car you don't have any mad ex girlfriends who like to let air out of tires do you? |
06-08-2006, 12:45 PM | #9 | |
Rep 7,519
Drives: 2009 E90 335i MT
Also, the valve caps won't hold the pressure. Check that the valve (the little thing inside the stem with the push wire in the center) is fully seated into the stem.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
