| 08-27-2025, 10:18 AM | #1 |
Rep 502
BMW M2 Service Bulletin List
Here you will find all of the service bulletins BMW has submitted to NHTSA for the M2 (G87). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/G87.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster. |
| 08-27-2025, 10:18 AM | #2 |
Rep 502
Recent Bulletins
SIB 11 01 26 (2026-02-06) BMW M2 CS 2026 (plus 2 other models) ENGINE Delivery Stop - Bearing Shell MC-11029098-0001.pdf SIB 41 07 25 (2026-01-08) BMW M2 2023,2024 (plus 7 other models) STRUCTURE: BODY While driving on a smooth and/or unevenroad, a ?cracking? sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side. MC-11027766-0001.pdf SIB 34 09 25 (2025-12-17) BMW M2 2024 (plus 4 other models) SERVICE BRAKES There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time. MC-11026950-0001.pdf SIB 32 01 23 (2025-08-08) BMW M2 2024 (plus 18 other models) STEERING When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard. MC-11021817-0001.pdf SIB 12 01 25 (2025-06-06) BMW M2 2024 (plus 5 other models) ELECTRICAL SYSTEM EMISSIONS RECALL 25E-A03: PROGRAM CONTOL UNITS (DME) MC-11019550-0001.pdf SIB 66 07 25 (2025-05-30) BMW M2 2024 (plus 15 other models) ELECTRICAL SYSTEM The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle. MC-11018732-0001.pdf SIB 51 25 24 (2024-10-18) BMW M2 2024 UNKNOWN OR OTHER Incorrect trim was installed for the cupholder, which does not match that of the surrounding center console panels . MC-11008993-0001.pdf SIB 51 24 24 (2024-09-19) BMW M2 2024 UNKNOWN OR OTHER Delivery Stop: Cupholder Trim MC-11008110-0001.pdf SIB 11 02 24 (2024-07-17) BMW M2 2024 (plus 2 other models) ENGINE The drive belt idler pulley bracket material does not have adequate hardness and the attaching bolts may loosen. MC-11005212-0001.pdf SIB 61 13 05 (2024-01-11) BMW M2 2023,2024 (plus 363 other models) ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY The electrical system of BMW vehicles has been subject to an ongoing development process over the last few years. This has led to increased demands being placed on the battery. This document covers important information for the dealer on how to handle "discharged battery" complaints. MC-10249027-0001.pdf SIB 31 01 24 (2024-01-09) BMW M2 2023,2024 (plus 10 other models) SUSPENSION With the vehicle is on a lift and the front struts are in the extended position, there may be a cracking and orclicking type noise when turning the steering wheel left/right. See attached video V31 01 24. The sound can reoccur when the vehicle is lowered, and the wheels are once again under load. The noise might also be heard for a short time while driving. MC-10249016-0001.pdf SIB 51 32 18 (2023-11-08) BMW M2 2023,2024 (plus 37 other models) EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, STRUCTURE, STRUCTURE: BODY: DOOR The paint finish on the door jamb (above the door striker) is scratched due to the inner door cavity window seal. MC-10245372-0001.pdf SIB 34 07 14 (2023-10-13) BMW M2 2023 (plus 30 other models) SERVICE BRAKES, HYDRAULIC Functional noises (squealing/honking) when braking shortly before the vehicle comes to a stop. CAUSE Material- MC-10244237-0001.pdf RECALL 23V099000 (2023-02-21) Affecting 3193 total vehicles BMW M2 2023 (plus 7 other models) ELECTRICAL SYSTEM: SOFTWARE, VISIBILITY: POWER WINDOW DEVICES AND CONTROLS BMW of North Americal, LLC (BMW) is recalling certain 2023 8 Series Coupe (840i, 840i xDrive, M850i xDrive, M8), 8 Series Convertible (840i, 840i xDrive, M850i xDrive, M8), 8 Series Gran Coupe (840i, 840i xDrive, M850i xDrive, M8, Alpine B8 xDrive), 2 Series Coupe (230i, 230i xDrive, M240i xDrive, M2), and 2022-2023 Z4 sDrive30i, Z4 M40i vehicles. When the digital key is removed from the vehicle, the Electronic Control Unit (ECU) software may still allow the power windows and sunroof to be closed. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 118, "Power-operated Window Systems." RCRIT-23V099-0830.pdf RCRIT-23V099-2989.pdf RCRIT-23V099-9684.pdf Last edited by analogue; 03-04-2026 at 07:41 AM.. |
| 08-30-2025, 07:02 AM | #3 |
![]() 1081
Rep 1,128
Great list! I know of at least one SIB that pertains to the G87 that is not listed:
SIB 66 07 25 G87 is not listed as an affected vehicle, but clicking the NHTSA link opens a PDF that explains the issue in detail and lists the G87 as an affected vehicle. I know because I just brought my 2025 M2 in to fix this problem. My software version was 03/2025.30. The dealership pushed version 07/2025.38 and that fixed the problem. See thread: https://g87.bimmerpost.com/forums/sh....php?t=2200322
Vehicles: 2025 Zandvoort Blue M2 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2021 Alpine White M2C 6MT; 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT |
| 01-06-2026, 01:15 PM | #5 |
Rep 502
New 2026-01-06
BMW M2 2024 (plus 4 other models) SERVICE BRAKES There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time. MC-11026950-0001.pdf |
| 01-23-2026, 07:32 AM | #6 |
Rep 502
New 2026-01-23
BMW M2 2023,2024 (plus 7 other models) STRUCTURE: BODY While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side. MC-11027766-0001.pdf |
M2M3M31206.00 |
| Bookmarks |
| Thread Tools | |
