Bumpy Ride
07-14-2005, 01:43 PM | #1 |
Rep 21
Bumpy Ride
Had my 330I, with the Bridgestone Potenza's that come with the Sport Package, out on the highway today. At a speed higher than 70 I noticed that the ride got a little bumpy. I wasn't sure if some balancing of the wheels was in order, or if this is just the feel from the performance run flats. Does anyone know if at higher speeds with these tires do you get a slight rough ride?
07-14-2005, 01:49 PM | #3 | |
Rep 679
07-14-2005, 02:05 PM | #4 |
Rep 874
It is interesting that you're describing the ride as "bumpy" while going at 70 mph on a highway. Did the road have bumps?
I would second the suggestion of checking your tire pressure (you probably want the < 100 mph setting with 4 passengers from the manual). My tires were over-inflated and the ride improved noticeably after I corrected the pressure.
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
07-14-2005, 02:16 PM | #5 |
Rep 21
No the road was smooth, and I had to correct the tire pressure after picking it up from the dealer some weeks ago. They are fine. It just felt like there was a flat spot on one of the tires, not that I think that's the problem, or wheel balancing was needed. But to be honest, the steering wheel was not visibly shaking.
07-14-2005, 02:30 PM | #6 |
Rep 210
But even if the steering wheel wasn't shaking, the ride still shouldn't feel bumpy. Was it like a consistent bumpiness? Like you'd feel the bump on every rotation of the wheel? Or was it more random? If it was random then it's probably just the road irregularities, but if it was like a consistent bumpiness then maybe your wheels need balancing or something.
07-14-2005, 02:41 PM | #7 |
Rep 21
It was consistent. The road is pretty smooth. I'm going to tell the dealer about it the next chance I get. It wasn't terrible, but it wasn't as smooth as I would expect.
07-14-2005, 02:48 PM | #8 |
Rep 614
I thought my ZSP car was pretty bumpy after picking it up, but after putting some mileage on the car, the ride seems to be getting a lot better. I have a E60 530i ZSP with Run-Flats and the ride seems to get better with age!
My E90 had balance problems and they rebalanced all four tires free of charge. My alignment was also off and veering to the right. Have your dealer look at your car as soon as possible since alignment and balance issues are only covered for the first 2 months or 2000 miles. -Chris |
07-14-2005, 03:00 PM | #9 | |
Rep 51
In my case, the dealer tried various things including re-balancing several times with no success. He eventually ended up swopping the wheels and tyres with a spare set they had in stock. Everything was OK from then on. Trying out another set of wheels and tyres is a good place to start. A couple of other things worth considering: 1. A tyre or tyres are incorrectly seated. Your dealer should be able to fix this by breaking the seal on the tyre and re-inflating. 2. It could also be a flat spot on a tyre/tyres.
____________________________________
330i SE Ti silver, sports steering wheel, heated sports seats, black dakota, lumbar support, adaptive headlights, 162 wheels, bluetooth phone prep, Hi-Fi stereo, folding mirrors. |
07-14-2005, 06:44 PM | #10 | |
Rep 91
check out http://www.corrinnemay.com
2006 325i Blk Sapphire Metallic, Beige Lthr, ZPP, nav, sat, xenon, fold-down seats and premium hi-fi. |
